creating rosject throwing error
How are we supposed to help you with the message you wrote?!?!
in my rosject as per information given by the jupyter notebook still getting the below error.
user:~/ros2_ws$ source install/setup.bash
ROS_DISTRO was set to ‘eloquent’ before. Please make sure that the environment does notmix paths from different distributions.
ROS_DISTRO was set to ‘melodic’ before. Please make sure that the environment does not mix paths from different distributions.
@sachingattani that is not an error. Please ignore it and continue with the other steps.
