Hi!
I am currently working on the final module for ROS2 Basics (Rust). I happen to have stumbled upon this issue when building the package, “topic_publisher_pkg”. Despite following all of the scripts/codes provided in the module, It indicates that the std_msgs package is unable to be detected by the system when running colcon build. May I kindly ask for your assistance on how to resolve this issue?
Thank you!
std_msgs is a package that comes with ROS 2 installation. Try sourcing it with:
source /opt/ros/humble/setup.bash (make sure the distribution matches)
And compile again.
Hi @roalgoal,
Thank you for your suggestion! I tried performing it prior to having the package compiled; however, the same problem still persists.
How did you create this package in the first place?
- Did you include
std_msgs as a dependency when creating the package, or
- You manually added it as a dependency after creating the package.
