Hi, I have a problem.
I follow the instruction but I got error: PackageNotFoundError: "package ‘nav2_lifecycle_manage’ not found.
I tried to add nav2_lifecycle_manage in package.xml but it does not work.
Please, check and help me.
Thanks.
import os
map_file = os.path.join(
get_package_share_directory('map_server'), 'config', 'turtlebot_area.yaml'
return LaunchDescription([
Node (
package='nav2_map_server',
executable='map_server',
name='map_server',
output='screen',
parameters=[
{'use_sim_time': True},
{'yaml_filename': map_file}
Node(
package='nav2_lifecycle_manage',
name='lifecycle_manager_mapper',
output='screen',
parameters=[
{'autostart': True},
{'node_names': ['map_server']}
from setuptools import setup
import os
from glob import glob
package_name = 'map_server'
setup(
name=package_name,
version='0.0.0',
packages=[package_name],
data_files=[
(os.path.join('share', package_name, 'launch'),
glob('launch/*.launch.py')),
(os.path.join('share', package_name, 'config'),
glob('config/*')),
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
<?xml version="1.0"?>
<package format="3">
<name>map_server</name>
<version>0.0.0</version>
<depend>nav2_lifecycle_manage</depend>
<test_depend>ament_copyright</test_depend>
<test_depend>ament_flake8</test_depend>
<test_depend>ament_pep257</test_depend>
<test_depend>python3-pytest</test_depend>
<export>
<build_type>ament_python</build_type>
</export>
</package>
