hello. im in execrise chapter 2 (manipulation moveit)
when i try to source the files:
source install/setup.bash
i got this error:
ROS_DISTRO was set to 'foxy' before. Please make sure that the environment does not mix paths from different distributions.
ROS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from differentdistributions.
can anyone help me to solve this?
thank you very much.
It is just a WARNING that informs you that the ROS_DISTRO environment variable was changed. And what the value was before.
I am assuming you are using ROS2. Please be aware that every time you want to execute a ROS2 package, you need to source ROS2 version by doing source /opt/ros/foxy/setup.bash. This will produce that warning message. It is to inform YOU (@Scotvers ) that the environment is now setup for ROS2.
Resetting the simulation will not solve this. As I said earlier, THIS IS NOT A PROBLEM !!!
Resetting simulation is also not a solution.
At this point I am presuming that you have never worked on ROS2 environment - either through ROS2 in 5 Days course or by physical work in your own computer/laptop.
I would like to suggest that you take a quick glance at the ROS2 Basics in 5 Days course - either C++ or Python - whichever language you prefer - and understand the basic environment of ROS2. Please stop working on ROS2 Manipulation course for a short while. Come back to the course after taking a ROS2 refresher.
I did not mean to discourage you. Please do not mistake me.
This is a very newbie mistake - which clearly shows that you had no prior experience in ROS2 environment.
