[ERROR] [bt_navigator-10]: process has died [pid 7362, exit code -11, cmd ‘/opt/ros/foxy/lib/nav2_bt_navigator/bt_navigator–ros-args -r __node:=bt_navigator --params-file /tmp/tmp8k1325vb -r /tf:=tf -r /tf_static:=tf_static’].
Greetings,
Can you please post the complete terminal Logs, and also the content of your Launch file. You can also debug using GDB utility to monitor the Logs in depth.
https://get-help.robotigniteacademy.com/t/ros2-navigation-chapter-1-demo-crashes/18092/2
Good day @Francisco5
This indicates that the process named bt_navigator has terminated unexpectedly. What you could do is to try and kill the pid and relaunch the node . Command as follows below
ps aux | grep gzserver
killa -9 7362
The 7362 serves as the pid . You can kill this and relaunch the node. You could also try updating the packages .
- sudo apt update
Check if the ros parameters : use_sim_time is set to True . if not set it to True. That’s if you using simulation.
Davies.O
Hi, @Francisco5
The error message you provided indicates that the bt_navigator process has died unexpectedly with exit code -11.
Here are some things you can do to resolve your issue:
- Check for Segmentation Faults:
ls -l core*(this will show you the core dump files which may help you find more information about the segmentation faults). - You can also review log files to see if any errors are cropping up.
- Update ROS Packages:
sudo apt update - Debugging: use the GNU Debugger to debug the
bt_navigatorprocess.
gdb --args ros2 launch [input navigation package] [input navigation file]
Marjia
