Hello, I am getting the following error and I dont think it is related to my coding, althought it could be :
Could someone help? @marco.nc.arruda ?
Hi @r.franklinismail ,
What are you trying to build in your workspace?
I could see some libs about msg generator, isn’t it?
Hi @r.franklinismail, seems like you are trying to create an srv msg, the error says that you are not using the syntax correctly, Here is a very simple example of a service that takes in a string and returns a string::
string str
string str
For more information: Create your own srv.
Please update on the error you are getting. Also, before building again, try to:
rm -rf build/ devel/
Errors << turtlebot:cmake /home/user/catkin_ws/logs/turtlebot/build.cmake.006.log
/opt/ros/noetic/share/genmsg/cmake/pkg-genmsg.cmake.em:56: error: <class ‘genmsg.base.InvalidMsgSpec’>: /home/user/catkin_ws/src/turtlebot/msg/servicemessage.srv: Invalid declaration: —
File “/opt/ros/noetic/lib/python3/dist-packages/genmsg/msg_loader.py”, line 287, in load_msg_from_file
return load_msg_from_string(msg_context, text, full_name)
File “/opt/ros/noetic/lib/python3/dist-packages/genmsg/msg_loader.py”, line 266, in load_msg_from_string
field_type, name = _load_field_line(orig_line, package_name)
File “/opt/ros/noetic/lib/python3/dist-packages/genmsg/msg_loader.py”, line 225, in _load_field_line
raise InvalidMsgSpec(“Invalid declaration: %s”%(orig_line))
genmsg.base.InvalidMsgSpec: Invalid declaration: —
During handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/em.py”, line 3302, in
if name == ‘main’: main()
File “/usr/lib/python3/dist-packages/em.py”, line 3300, in main
invoke(sys.argv[1:])
File “/usr/lib/python3/dist-packages/em.py”, line 3283, in invoke
interpreter.wrap(interpreter.file, (file, name))
File “/usr/lib/python3/dist-packages/em.py”, line 2295, in wrap
self.fail(e)
File “/usr/lib/python3/dist-packages/em.py”, line 2284, in wrap
callable(*args)
File “/usr/lib/python3/dist-packages/em.py”, line 2359, in file
self.safe(scanner, done, locals)
File “/usr/lib/python3/dist-packages/em.py”, line 2401, in safe
self.parse(scanner, locals)
File “/usr/lib/python3/dist-packages/em.py”, line 2421, in parse
token.run(self, locals)
File “/usr/lib/python3/dist-packages/em.py”, line 1425, in run
interpreter.execute(self.code, locals)
File “/usr/lib/python3/dist-packages/em.py”, line 2595, in execute
_exec(statements, self.globals, locals)
File “”, line 38, in
File “/opt/ros/noetic/lib/python3/dist-packages/genmsg/deps.py”, line 45, in find_msg_dependencies_with_type
spec = genmsg.msg_loader.load_msg_from_file(msg_context, msg_file, full_type_name)
File “/opt/ros/noetic/lib/python3/dist-packages/genmsg/msg_loader.py”, line 289, in load_msg_from_file
raise InvalidMsgSpec(’%s: %s’%(file_path, e))
genmsg.base.InvalidMsgSpec: /home/user/catkin_ws/src/turtlebot/msg/servicemessage.srv: Invalid declaration: —
CMake Error at /opt/ros/noetic/share/catkin/cmake/safe_execute_process.cmake:11 (message):
execute_process(/home/user/catkin_ws/build/turtlebot/catkin_generated/env_cached.sh
“/usr/bin/python3” “/usr/lib/python3/dist-packages/em.py” “–raw-errors”
“-F”
“/home/user/catkin_ws/build/turtlebot/cmake/turtlebot-genmsg-context.py”
“-o” “/home/user/catkin_ws/build/turtlebot/cmake/turtlebot-genmsg.cmake”
“/opt/ros/noetic/share/genmsg/cmake/pkg-genmsg.cmake.em”) returned error
code 1
/opt/ros/noetic/share/catkin/cmake/em_expand.cmake:25 (safe_execute_process)
/opt/ros/noetic/share/genmsg/cmake/genmsg-extras.cmake:303 (em_expand)
CMakeLists.txt:73 (generate_messages)
From the source code you pasted, it does not look to have syntax error.
There may be other things in your workspace that is preventing you from compiling the code properly.
If the syntax detector is pointing some error, there may be invalid characters there. It may happen if you copy the code from some other place (editor) that is configured to use a different encoding.
I can’t see further errors there, our team is analyzing it and will keep you posted
Have you sourced the correct ROS version ?
I mean could you try to:
cd ~/catkin_ws
rm -rf build devel
source /home/simulations/public_sim_ws/devel/setup.bash
catkin_make
source devel/setup.bash
rospack profile
And then execute the script that uses those service messages?
The error with catkin_make is below.
Thank you guys for all your support!!!
– Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
self.fail(e)
callable(*args)
execute_process(/home/user/catkin_ws/build/catkin_generated/env_cached.sh
“-F”
code 1
turtlebot/CMakeLists.txt:73 (generate_messages)
– Configuring incomplete, errors occurred!
See also “/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log”.
See also “/home/user/catkin_ws/build/CMakeFiles/CMakeError.log”.
Invoking “cmake” failed
is it something in my Cmake file? Ill paste tthat below:
> Blockquote
project(turtlebot)
rospy
std_msgs
message_generation
# catkin_python_setup()
## * In the file package.xml:
add_message_files(
FILES
servicemessage.srv
FindWall.msg
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs # Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
INCLUDE_DIRS include
LIBRARIES turtlebot
CATKIN_DEPENDS
rospy
DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/turtlebot.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/turtlebot_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_turtlebot.cpp)
# endif()
# catkin_add_nosetests(test)
Here is a directory of my package. I can upload any file or script youdl like
Based on your CMake file and file system, I see a potential issue.
CMake:
You have placed your servicemessage.srv file inside of the add_message_files function instead of the add_service_files function just below. These are different functions for a reason.
File system:
Similarly, you placed the file “servicemessage.srv” in the msg/ folder instead of creating a /srv folder.
It can be confusing because we tend to refer to the contents of the .srv file as a “service message”, but I believe that they do need separated in the Cmake file and be placed in the expected file location
Package complied!!
I did have to make a few other changes. I tjhink its inconsequential from reading online.
catkin_package(
INCLUDE_DIRS # include
LIBRARIES turtlebot
CATKIN_DEPENDS
rospy
#DEPENDS system_lib
Thank you @_RM @marco.nc.arruda @duckfrost @u1802520 @bayodesegun !!!
