I to use the stables baselines package instead of the baselines package. After running it i get the following error message. Do i have to install further depencies?
Thank you for your help
user:~/catkin_ws/src/stable-baselines/stable_baselines/deepq/experiments$ python train_cartpole.py
2020-03-26 14:12:49.229370: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘libnvinfer.so.6’; dlerror: libnvinfer.so.6: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/home/user/catkin_ws/devel/lib:/home/user/simulation_ws/devel/lib:/home/simulations/public_sim_ws/devel/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/x86_64-linux-gnu:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/usr/local/cuda-10.2/lib64:/home/user/.catkin_ws_python3/src/TensorRT-7.0.0.11/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64:/usr/lib/x86_64-linux-gnu/gazebo-7/plugins
2020-03-26 14:12:49.229519: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘libnvinfer_plugin.so.6’; dlerror: libnvinfer_plugin.so.6: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/home/user/catkin_ws/devel/lib:/home/user/simulation_ws/devel/lib:/home/simulations/public_sim_ws/devel/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/x86_64-linux-gnu:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/usr/local/cuda-10.2/lib64:/home/user/.catkin_ws_python3/src/TensorRT-7.0.0.11/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64:/usr/lib/x86_64-linux-gnu/gazebo-7/plugins
2020-03-26 14:12:49.229547: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:30] Cannot dlopen some TensorRT libraries. If you would liketo use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
File “train_cartpole.py”, line 5, in
from stable_baselines.deepq import DQN, MlpPolicy
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/init.py”, line 1, in
from stable_baselines.a2c import A2C
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/a2c/init.py”, line 1, in
from stable_baselines.a2c.a2c import A2C
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/a2c/a2c.py”, line 7, in
from stable_baselines import logger
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/logger.py”, line 17, in
from stable_baselines.common.misc_util import mpi_rank_or_zero
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/common/init.py”, line 9, in
from stable_baselines.common.cmd_util import make_vec_env
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/common/cmd_util.py”, line 13, in
from stable_baselines.common.atari_wrappers import make_atari, wrap_deepmind
File “/home/user/catkin_ws/src/stable-baselines/stable_baselines/common/atari_wrappers.py”, line 6, in
import cv2 # pytype:disable=import-error
ImportError: /opt/ros/kinetic/lib/python2.7/dist-packages/cv2.so: undefined symbol: PyCObject_Type
and the error just appeared
