Hi I am getting this many times when I am making launching file from moveit to Gazebo. I have followed all guidelines in ros manipulation course. Your suggestions will,be helpful.
Thanks
Harshal
Hello @more.1787364,
It looks like the issue is with an argument named execution_type in the mrm_moveit_controller_manager.launch.xml file. Try commenting this parameter and see if solves the problem.
this is my file. I commented but have same issue.
I am using local computer with ubuntu 20.04 and noetic ros
Then this is probably the reason since our courses are working on Ubuntu 16 + ROS Kinetic. We are planning to port all the courses to Noetic in the close future though. I would suggest you look for the latest MoveIt tutorials which are based on Noetic.
