While attempting exercise 5.1 in the ROS Basics in 5 days (c++), I keep coming up with the error as seen below.
While executing catkin_make, it seems as though the service_client_pkg package is not recognised.
I have also tried sourcing ros, but didn’t seem to work.
Any help would be greatly appreciated!
user:~/catkin_ws$ source devel/setup.bash
user:~/catkin_ws$ catkin_make
#### Running command: "make cmake_check_build_system" in "/home/user/catkin_ws/build"
#### Running command: "make -j8 -l8" in "/home/user/catkin_ws/build"
[ 0%] Built target rosgraph_msgs_generate_messages_py
[ 0%] Built target roscpp_generate_messages_py
[ 0%] Built target std_msgs_generate_messages_eus
[ 0%] Built target roscpp_generate_messages_nodejs
[ 0%] Built target rosgraph_msgs_generate_messages_cpp
[ 0%] Built target std_msgs_generate_messages_cpp
[ 0%] Built target rosgraph_msgs_generate_messages_eus
[ 0%] Built target rosgraph_msgs_generate_messages_lisp
[ 0%] Built target roscpp_generate_messages_lisp
[ 0%] Built target std_msgs_generate_messages_lisp
[ 0%] Built target rosgraph_msgs_generate_messages_nodejs
[ 0%] Built target roscpp_generate_messages_eus
[ 0%] Built target roscpp_generate_messages_cpp
[ 0%] Built target std_msgs_generate_messages_nodejs
[ 0%] Built target std_msgs_generate_messages_py
[100%] Built target obstacle_avoider
user:~/catkin_ws$ roslaunch service_client_pkg service_client_launch.launch
... logging to /home/user/.ros/log/336d4f1e-963a-11ed-9cb3-0242ac150007/roslaunch-2_xterm-11575.log
Press Ctrl-C to interrupt
started roslaunch server http://2_xterm:39355/
SUMMARY
PARAMETERS
* /rosdistro: noetic
* /rosversion: 1.15.9
NODES
iri_wam_reproduce_trajectory (iri_wam_reproduce_trajectory/iri_wam_reproduce_trajectory_node)
service_client (service_client_pkg/simple_service_client)
traj_by_name_node (trajectory_by_name/traj_by_name.py)
ROS_MASTER_URI=http://2_simulation:11311
process[iri_wam_reproduce_trajectory-1]: started with pid [11583]
process[traj_by_name_node-2]: started with pid [11584]
ERROR: cannot launch node of type [service_client_pkg/simple_service_client]: Cannot locate node of type [simple_service_client] in package [service_client_pkg]. Make sure file exists in package path and permission is set to executable (chmod +x)
[ INFO] [1673947273.851293487]: Waiting for action server to start.
[ INFO] [1673947273.881770691]: Ready execute trajectories
