Example 1.6 Error with #include "rclcpp/rclcpp.hpp" My First ROS Program ROS2BasicConcepts
Following the first step of Example 1.6 I copy the code of simple.cpp and paste in in a new file. However I get this error that the file “rclcpp/rclcpp.hpp” is not found.
In addition if I continue and I run the colcon build The system gives a package failed: my_package.
I just followed the notebooks instructions and seems to work without issues:
// Here we are including all the headers necessary to use the most common public pieces of the ROS system
// In this case we use the rclcpp client library, which provides a C++ Api for interacting with ROS
// Always, when we create a new C++ file, we will need to add this include:
// We start the main C++ program
int main(int argc, char * argv[])
  // We initiate the rclcpp client library
  rclcpp::init(argc, argv);
  // We initiate a ROS node called ObiWan
  auto node = rclcpp::Node::make_shared("ObiWan");
  // This is the same as a print in ROS
  RCLCPP_INFO(node->get_logger(), "Help me Obi-Wan Kenobi, you're my only hope");
  // We shutdown the rclcpp client library
  rclcpp::shutdown();
  // We end our program
  return 0;
And I added this code CmakeLists.txt:
cmake_minimum_required(VERSION 3.5)
project(my_package)
# Default to C99
if(NOT CMAKE_C_STANDARD)
  set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
  set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# find dependencies
find_package(rclcpp REQUIRED)
if(BUILD_TESTING)
  # uncomment the line when a copyright and license is not present in all source files
  #set(ament_cmake_copyright_FOUND TRUE)
  # uncomment the line when this package is not in a git repo
  #set(ament_cmake_cpplint_FOUND TRUE)
endif()
add_executable(simple_node src/simple.cpp)
ament_target_dependencies(simple_node rclcpp)
install(TARGETS
   simple_node
   DESTINATION lib/${PROJECT_NAME}
install(DIRECTORY
  launch
  DESTINATION share/${PROJECT_NAME}/
ament_package()
Please check that you compiled and added the correct code. If it doesnt work please tell us agian.
colcon build
It is still giving me the same error that it doesn’t find the #include “rclcpp/rclcpp.hpp” file.
I was able to do the colcon buil but when ros2 launch I get the following error:
user:~/ros2_ws$ ros2 launch my_package my_package_launch_file.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2021-03-16-09-48-47-544838-2_xterm-5411
Task exception was never retrieved
future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:271> exception=SubstitutionFailure("executable 'simple' not found on the libexec directory '/home/user/ros2_ws/install/my_package/lib/my_package' ")>
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py", line 273, in _process_one_event
    await self.__process_event(next_event)
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py", line 293, in __process_event
    visit_all_entities_and_collect_futures(entity, self.__context))
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 45, in visit_all_entities_and_collect_futures
    futures_to_return += visit_all_entities_and_collect_futures(sub_entity, context)
  [Previous line repeated 1 more time]
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 38, in visit_all_entities_and_collect_futures
    sub_entities = entity.visit(context)
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/action.py", line 108, in visit
    return self.execute(context)
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/actions/node.py", line 442, in execute
    ret = super().execute(context)
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/execute_process.py", line 775, in execute
    self.__expand_substitutions(context)
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/execute_process.py", line 635, in __expand_substitutions
    cmd = [perform_substitutions(context, x) for x in self.__cmd]
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/execute_process.py", line 635, in <listcomp>
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/perform_substitutions_impl.py", line 26, in perform_substitutions
    return ''.join([context.perform_substitution(sub) for sub in subs])
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/perform_substitutions_impl.py", line 26, in <listcomp>
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_context.py", line 184, in perform_substitution
    return substitution.perform(self)
  File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/substitutions/executable_in_package.py", line 84, in perform
    raise SubstitutionFailure(
launch.substitutions.substitution_failure.SubstitutionFailure: executable 'simple' not found on the libexec directory '/home/user/ros2_ws/install/my_package/lib/my_package'
I found the error, It is because I modified the launch file so the executable will be named simple as I thought it was the name of the cpp file but I realised because of the CMakeList that it is renamed simple_node.
Even though it already works I still find the problem of the file and it gives me this red error at the side of the files that I showed in the first message.
Thank you for your help.
