Hello Everyone, please help!
I have been working through the services section of ROS in 5 Days. I am currently stuck with an error that MyCustomServiceMessage has no attribute ‘duration’. I have remdade the package, ensured catkin_make was succesful, even by compiling individual packages and I have sourced my workspace on every shell. To no prevail!
Here is my_custom_srv_msg_pkg
srv/MyCustomServiceMessage.srv
int32 duration
bool success
CMakeLists.txt
project(my_custom_srv_msg_pkg)
## Here is where all the packages needed to COMPILE the messages of topics, services and actions go.
## It's only getting its paths, and not really importing them to be used in the compilation.
## It's only for further functions in CMakeLists.txt to be able to find those packages.
## In package.xml you have to state them as build
std_msgs
message_generation
## In this function will be all the action messages of this package ( in the action folder ) to be compiled.
## You can state that it gets all the actions inside the action directory: DIRECTORY action
## Or just the action messages stated explicitly: FILES my_custom_action.action
## In your case you only need to do one of two things, as you wish.
add_service_files(
FILES
## Here is where the packages needed for the action messages compilation are imported.
generate_messages(
DEPENDENCIES
std_msgs
## State here all the packages that will be needed by someone that executes something from your package.
## All the packages stated here must be in the package.xml as exec_depend
catkin_package(
CATKIN_DEPENDS rospy
include_directories(
${catkin_INCLUDE_DIRS}
package.xml
<?xml version="1.0"?>
0.0.0
The my_custom_srv_msg_pkg package
user
TODO
```Here is my bb8_move_custom_service_server.py
# you import the service message python classes generated from Empty.srv.
from my_custom_srv_msg_pkg.srv import MyCustomServiceMessage, MyCustomServiceMessageRequest, MyCustomServiceMessageResponse
def my_callback(request):
move = Twist()
move.linear.x = 0
move.angular.z = 0
pub.publish(move)
print("My_callback has been called")
# the service Response class, in this case EmptyResponse
return MyCustomServiceMessageResponse()
# return MyServiceResponse(len(request.words.split()))
rospy.init_node('bb8_service_server')
# create the Service called my_service with the defined callback
my_service = rospy.Service(
'/move_bb8_in_circle_custom', MyCustomServiceMessage, my_callback)
rospy.spin() # maintain the service open.
I have been so focused on getting the custom service working I haven’t even explored BB8 control yet. Any suggestions greatly appreciated! thank you!
