I was going about completing the example 6.8 by making my_custom_srv_msg_pkg and performed all the steps as directed and ended up with a ModuleNotFound error and then I deleted the build directory thinking that I’ll get it back using the catkin_make command. However, upon implementation of that command I got “Invoking “cmake” failed” error. I also deleted the packages of the example thinking that maybe it might help resolve the issue yet the problem is persistent. Please help.
Hi @Riten_Shah ,
The error is quite self-explanatory!
It says message file not found and it refers to the add_message_files routine.
So…
- Either you did not make the custom message
OR - You did not compile the package after making the custom message file.
So, retrace your notes on how to make the custom message working and you can get this working.
