Executable not found on the libexec directory when trying to launch
Trying to do the basic wall following robot as part of a course and running into this error:
launch.substitutions.substitution_failure.SubstitutionFailure: executable 'follow_wall' not found on the libexec directory '/home/user/ros2_ws/install/wall_follower/lib/wall_follower'
when I try to run:
ros2 launch wall_follower start_wall_following.launch.py
My file structure looks like this:
The 3 files, shown below:
follow_wall
import rclpy
# import the ROS2 python libraries
from rclpy.node import Node
# import the Twist module from geometry_msgs interface
# import the LaserScan module from sensor_msgs interface
class WallFollow(Node):
        # Here you have the class constructor
        # call the class constructor
        super().__init__('follow_wall')
        # create the publisher object
        # create the subscriber object
        self.subscriber = self.create_subscription(
            LaserScan, '/scan', self.laser_callback, QoSProfile(depth=10, reliability=ReliabilityPolicy.BEST_EFFORT))
        # define the timer period for 0.5 seconds
        self.timer_period = 0.5
        # define the variable to save the received info
        self.laser_forward = 0
        self.laser_right = 0
        # create a Twist message
        self.cmd = Twist()
        self.timer = self.create_timer(self.timer_period, self.motion)
        # Save the laser info
        self.laser_forward = msg.ranges[359]
        self.laser_right = msg.ranges[90]
    def motion(self):
        # print the data
        self.get_logger().info('I receive: "%s"' % str(self.laser_forward))
        # Logic of move
        if self.laser_right > 0.3:
            self.cmd.linear.x = 0.5
            self.cmd.angular.z = -0.2
        elif self.laser_right < 0.2:
            self.cmd.angular.z = 0.2
        else:
            self.cmd.angular.z = 0.0
        if self.laser_forward < 0.5:
            self.cmd.angular.z = 0.5
        # Publishing the cmd_vel values to a Topic
def main(args=None):
    rclpy.init(args=args)
    follow_wall = WallFollow()
    rclpy.spin(follow_wall)
    # Explicity destroy the node
    follow_wall.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
setup.py
from setuptools import setup
import os
from glob import glob
package_name = 'wall_follower'
setup(
    name=package_name,
    version='0.0.0',
    packages=[package_name],
    data_files=[
    zip_safe=True,
    maintainer='somebody very awesome',
    maintainer_email='user@user.com',
    tests_require=['pytest'],
    entry_points={
        'console_scripts': [
            'simple_subscriber = wall_follower.follow_wall:main'
    return LaunchDescription([
        Node(
            package='wall_follower',
            executable='follow_wall',
            output='screen'),
EDIT
ok one mistake I found was that this line in setup.py:
  entry_points={
should not say simple subscriber but instead wall_follower. Fixing that did bring progress and now a new error has arisen (full output of attempted launch):
INFO] [launch]: All log files can be found below /home/user/.ros/log/2023-01-01-21-08-08-165490-2_xterm-22022
[INFO] [follow_wall-1]: process started with pid [22084]
[follow_wall-1] Traceback (most recent call last):
[follow_wall-1]   File "/home/user/ros2_ws/install/wall_follower/lib/wall_follower/follow_wall", line 33, in <module>
[follow_wall-1]     sys.exit(load_entry_point('wall-follower==0.0.0', 'console_scripts', 'follow_wall')())
[follow_wall-1]   File "/home/user/ros2_ws/install/wall_follower/lib/python3.8/site-packages/wall_follower/follow_wall.py", line 61, in main
[follow_wall-1]     follow_wall = WallFollow()
[follow_wall-1]   File "/home/user/ros2_ws/install/wall_follower/lib/python3.8/site-packages/wall_follower/follow_wall.py", line 18, in __init__
[follow_wall-1]     self.publisher_ = self.create_publisher(Twist, 'cmd_vel', 10)
[follow_wall-1]   File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/node.py", line 1140, in create_publisher
[follow_wall-1]     check_for_type_support(msg_type)
[follow_wall-1]   File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/type_support.py", line 20, in check_for_type_support
[follow_wall-1]     ts = msg_type.__class__._TYPE_SUPPORT
[follow_wall-1] AttributeError: type object 'type' has no attribute '_TYPE_SUPPORT' This might be a ROS 1 message type but it should be a ROS 2 message type. Make sure to source your ROS 2 workspace after your ROS 1 workspace.
[ERROR] [follow_wall-1]: process has died [pid 22084, exit code 1, cmd '/home/user/ros2_ws/install/wall_follower/lib/wall_follower/follow_wall --ros-args'].
I also often get this warning when trying to source:
OS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from different distributions.
I noticed there are different types of source commands, not sure which to use. I also noticed there was ros 1 and ros 2 ways of launching, and different sourcing for each, Very lost here on which to use, or generally how to get my code to run.
Hi @asengupt ,
Welcome to this Community!
If you are working on ROS2 Basics Rosject, each terminal you open are already pre-sourced with ROS2. So if you make any mistakes in your setup.py file, after fixing that, you just rebuild the package and source your install/setup.bash script.
Since you have already fixed your simple_subscriber issue, you can just rebuild your package and source setup.bash and you are good to go!
This is one of the most posted error in this forum and the solution is very simple - source the workspace before building (in case of ROS2 it is already sourced to ROS2, as said earlier) and source your setup.bash after colcon builds.
You get this note if you source ROS2 after ROS1. This is the procedure - so you can ignore this warning / output.
Good afternoon
I have exactly the same problem but after building my package and doing source install/setup.sh in the ros2_ws.
My setup file seems to be correct.
I would like to know why it doesn’t work.
The error
File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/substitutions/executable_in_package.py", line 84, in perform
    raise SubstitutionFailure(
launch.substitutions.substitution_failure.SubstitutionFailure: executable 'wall_following' not found on the libexec directory '/home/user/ros2_ws/install/wall_follower/lib/wall_follower'
My main code
import rclpy
        # Constructer of the node
        super().__init__('wall_follower')
        # Constructer of the publisher
        self.publisher = self.create_publisher(Twist, 'cmd_vel', 10)
        # Constructer of the subscriber
            LaserScan, 'scan', self.laser_callback, 10)
        # Define the variables
        # Define the timer period for 0.5 seconds
        # Initialisation of the laser_90_degree value at 0
        self.laser_90_degree = 0
        # Initialisation of the variable that will take the Twist message
        self.move = Twist()
        # Generate the action, here moving the robot with publication in the topic
    def laser_callback(self, sensor_msgs):
        self.laser_90_degree = sensor_msgs.ranges[90]
    def motion(self):
        # Print the degug function at the info level the information related to the laser
        self.get_logger().info('I receive: "%s"' % str(self.laser_90_degree))
        # Acion = movement of the robot according to the laser reading
        if(self.laser_90_degree > 0.3):  # Move forward and turn toward the wall
            self.move.linear.x = 0.5
            self.move.angular.z = 0.2
            print(1)
        elif(self.laser_90_degree > 0.2 and self.laser_90_degree < 0.3):  # Move forward
            self.move.angular.z = 0.0
            print(2)
        else:
            if(self.laser_90_degree < 0.2):  # Move forward and turn backward the wall
                self.move.angular.z = -0.2
                print(3)
            else:
                self.get_logger().info('Error! The distance is "%s"' % str(self.laser_90_degree))
                self.move.linear.x = 0.0
    # Initialize the ROS communication
    # Declare the node constructor
    WallFollower = WallFollow()
    # Pause the program execution, waits for a request to kill the node (ctrl+c)
    rclpy.spin(WallFollower)
    WallFollower.destroy_node()
    # Shutdown the ROS communication
    rclpy.shutdown()
    main()
My launch code
        Node(
            executable='wall_following',
            output='screen'),
My setup code
import os
setup(
    name=package_name,
    version='0.0.0',
    data_files=[
    zip_safe=True,
    maintainer='user',
    entry_points={
            'wall_followers = wall_follower.wall_following:main'
Hi @ClairePottier ,
This line in your launch file:
must be the same as the left hand side variable in your setup.py file console_scripts
So here is your fix:
Replace this line: 'wall_followers = wall_follower.wall_following:main'
with this line: 'wall_following = wall_follower.wall_following:main'
Do not make any changes to your launch file.
Let me know if you still have problems.
Hi Girish
It worked! Thanks!
Claire
