I’m having the exact same problem, but when using rosrun I’m getting: “found the following but they are either not files or not executables” I tried using the solution posted for the exercise but the error is showing with both solutions, mine and the one given by the course
Hi @jaime,
Welcome to the Community!
The issue you are having is different. Could you check the following?
- Have you compiled you package with
catkin_make? - After that, have you run
source devel/setup.bashon every shell you are using? - Are you also using the right names?
