I am trying to execute the code:
rosrun map_server map_server my_map.yaml
but then i get this error:
[ERROR] [1640580945.903622164]: Map_server could not open my_map.yml.
What am I doing wrong? my_map.yaml was generated in previous step as per the instructions using:
rosrun map_server map_saver -f my_map
I also have made sure all processes were shut off using Ctrl+C. I tried moving the file to the catkin/src/ location also and it did not work.
Any help you can provide is appreciated. Thank you!
