I seem to be having an issue with a linking error that doesn’t seem to make sense to me.
execute_trajectory.cpp:(.text+0x1ce): undefined reference to `ros::getPath(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&)’
I’ve traced it to the following line in the solution .cpp file:
trajectory.request.file = ros::getPath(“iri_wam_reproduce_trajectory”) + “/config/get_food.txt”;
if I replace the right side of the assignment with the actual path, it works… if I try to use the getPath function it errors out.
thoughts?
Hi @tchav006,
First of all, welcome to the community!
Now to your question. The hint here is the part of the error that says undefined reference to ros::package::getPath…so here are the things you can check:
- Did you
#include <ros/package.h>
? in your C++ program?
- Did you modify your
CMakeLists.txt
as mentioned in the notebook? Excepts:
In order to be able to properly compile the the ros::package::getPath() function, you will need to add dependencies to the roslib library. You can do that by modifying the find_package() function in the CmakeLists.txt file. Like this:
roscpp
roslib
- Did you compile your package with
catkin_make
and then source devel/setup.bash
on every shell after that?
Please let’s know how it goes. Cheers!
