Hello @ROSBUILD,
here is thes short answer:
Run this command to see the contents of that file:
cat /home/simulations/public_sim_ws/src/all/husky/husky/husky_navigation/launch/amcl.launch
Here is the long answer:
You can use the rospack find [package_name] command to get the the path to a package.
Thus, to get the path to the husky_navigation package you would type:
rospack find husky_navigation
This will show this path:
you can see the directories inside that package by typing:
ls /home/simulations/public_sim_ws/src/all/husky/husky/husky_navigation
as you can see there is a launch directory:
CHANGELOG.rst CMakeLists.txt config launch maps package.xml
look at the files inside the launch directory (since we want to display the content of a launch file):
ls /home/simulations/public_sim_ws/src/all/husky/husky/husky_navigation/launch
You will see that this directory has the launch file that you are looking for (among other launch files):
amcl.launch exploration_demo.launch move_base.launch
amcl_demo.launch gmapping.launch move_base_demo.launch
exploration.launch gmapping_demo.launch move_base_mapless_demo.launch
Finally to see the contents of this amcl launch file use the cat command, providing the path to the file like this:
For completeness, below a (shorter version of) the content of that launch file:
<?xml version="1.0"?>
<launch>
<arg name="use_map_topic" default="true"/>
<arg name="scan_topic" default="scan" />
<node pkg="amcl" type="amcl" name="amcl">
<param name="use_map_topic" value="$(arg use_map_topic)"/>
<!-- Publish scans from best pose at a max of 10 Hz -->
<param name="odom_model_type" value="diff"/>
<param name="odom_alpha5" value="0.1"/>
<param name="gui_publish_rate" value="10.0"/>
<param name="laser_max_beams" value="60"/>
<param name="laser_max_range" value="12.0"/>
<param name="min_particles" value="500"/>
<param name="max_particles" value="2000"/>
<param name="kld_err" value="0.05"/>
<param name="kld_z" value="0.99"/>
<param name="odom_alpha1" value="0.2"/>
<param name="odom_alpha2" value="0.2"/>
<!-- translation std dev, m -->
<param name="odom_alpha3" value="0.2"/>
<param name="odom_alpha4" value="0.2"/>
<param name="laser_z_hit" value="0.5"/>
<param name="laser_z_short" value="0.05"/>
<param name="laser_z_max" value="0.05"/>
<param name="laser_z_rand" value="0.5"/>
<param name="laser_sigma_hit" value="0.2"/>
<param name="laser_lambda_short" value="0.1"/>
<param name="laser_model_type" value="likelihood_field"/>
<!-- <param name="laser_model_type" value="beam"/> -->
<param name="laser_likelihood_max_dist" value="2.0"/>
<param name="update_min_d" value="0.25"/>
<param name="update_min_a" value="0.2"/>
<param name="odom_frame_id" value="odom"/>
<param name="resample_interval" value="1"/>
<!-- Increase tolerance because the computer can get quite busy -->
<param name="transform_tolerance" value="1.0"/>
<param name="recovery_alpha_slow" value="0.0"/>
<param name="recovery_alpha_fast" value="0.0"/>
<remap from="scan" to="$(arg scan_topic)"/>
</node>
</launch>
Hope this helps,
Roberto
