I was checking the solution for exercise 4.5 , something confuse me. below there is the launch file given in the solution page
<?xml version="1.0"?>
<launch>
<!-- Run the map server -->
<arg name="map_file" default="$(find husky_navigation)/maps/my_map.yaml"/>
<node name="map_server" pkg="map_server" type="map_server" args="$(arg map_file)" />
<!--- Run AMCL -->
<include file="$(find husky_navigation)/launch/amcl.launch" />
<arg name="no_static_map" default="false"/>
<arg name="base_global_planner" default="navfn/NavfnROS"/>
<arg name="base_local_planner" default="dwa_local_planner/DWAPlannerROS"/>
<!-- <arg name="base_local_planner" default="base_local_planner/TrajectoryPlannerROS"/> -->
<node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
<param name="base_global_planner" value="$(arg base_global_planner)"/>
<param name="base_local_planner" value="$(arg base_local_planner)"/>
<rosparam file="$(find husky_navigation)/config/planner.yaml" command="load"/>
<!-- observation sources located in costmap_common.yaml -->
<rosparam file="$(find husky_navigation)/config/costmap_common.yaml" command="load" ns="global_costmap" />
<rosparam file="$(find husky_navigation)/config/costmap_common.yaml" command="load" ns="local_costmap" />
<!-- local costmap, needs size -->
<rosparam file="$(find husky_navigation)/config/costmap_local.yaml" command="load" ns="local_costmap" />
<param name="local_costmap/width" value="10.0"/>
<param name="local_costmap/height" value="10.0"/>
<!-- static global costmap, static map provides size -->
<rosparam file="$(find husky_navigation)/config/costmap_global_static.yaml" command="load" ns="global_costmap" unless="$(arg no_static_map)"/>
<!-- global costmap with laser, for odom_navigation_demo -->
<rosparam file="$(find husky_navigation)/config/costmap_global_laser.yaml" command="load" ns="global_costmap" if="$(arg no_static_map)"/>
<param name="global_costmap/width" value="100.0" if="$(arg no_static_map)"/>
<param name="global_costmap/height" value="100.0" if="$(arg no_static_map)"/>
</node>
</launch>
Nowhere in the solution the parameters file “my_move_base_params.yaml” ,which also part of solution, was referred.
shouldnt there be something like
<rosparam file="$(find my_move_base_launcher)/params/my_move_base_params.yaml" command="load" />
