Respected all,
This above is the exercise 9.4…I’m getting few issues here
This second pic shows what I got on my PC. As you see the output I’m getting is not even close to what the exercise is expecting. What happened is:
- I added the Camera, and it’s showing just a grid kind of thing(which can be seen in this 2nd pic above) with something really small in the middle. These small points at middle make small movements. I waited for it, thinking something might be loading, but nothing changed. Is it what it should look like ? If yes, then what’s the benefit of it because I can’t get any information from it.
- The LaserScan isn’t doing anything at all. I tried changing it’s different values like Size(m) Alpha and Decay Time but still I couldn’t see any change.
- Similarly I didn’t see anything happening as I added PointCloud. I played with it too but couldn’t see anything.
Your kind attention is appreciated. Thank you
Abdul Basit Dost
