I have trouble to understand and fix this issue when I build my package. It seems that I have a problem with the action client class that I have coded.
Does anyone can guide me this please ? Below the codes.
Error code when building:
/home/user/ros2_ws/src/wall_following_pkg/src/actionClientRecordOdom.cpp:51:38: error: no match for 'operator=' (operand types are 'rclcpp_action::Client<custom_interfaces::action::OdomRecord>::GoalResponseCallback' {aka 'std::function<void(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<custom_interfaces::action::OdomRecord> > >)>'} and 'std::_Bind_helper<false, void (ActionClientOdomRecorder::*)(const std::shared_ptr<rclcpp_action::ClientGoalHandle<custom_interfaces::action::OdomRecord> >&), ActionClientOdomRecorder*, const std::_Placeholder<1>&>::type' {aka 'std::_Bind<void (ActionClientOdomRecorder::*(ActionClientOdomRecorder*, std::_Placeholder<1>))(const std::shared_ptr<rclcpp_action::ClientGoalHandle<custom_interfaces::action::OdomRecord> >&)>'})
51 | std::placeholders::_1);
cpp of the action client class:
#include "actionClientRecordOdom.hpp"
using OdomRecord = custom_interfaces::action::OdomRecord;
using GoalHandleOdom = rclcpp_action::ClientGoalHandle<OdomRecord>;
ActionClientOdomRecorder::ActionClientOdomRecorder(
const rclcpp::NodeOptions &node_options)
: Node("action_client_record_odom_node", node_options), goal_done_(false),
send_goal_activate_(false) {
this->client_ptr_ = rclcpp_action::create_client<OdomRecord>(
this->get_node_base_interface(), this->get_node_graph_interface(),
this->get_node_logging_interface(), this->get_node_waitables_interface(),
"odom_record");
this->timer_ = this->create_wall_timer(
std::chrono::milliseconds(100),
std::bind(&ActionClientOdomRecorder::send_goal, this));
void ActionClientOdomRecorder::activate_send_goal() {
send_goal_activate_ = true;
void ActionClientOdomRecorder::send_goal() {
using namespace std::placeholders;
this->goal_done_ = false;
if (!send_goal_activate_) {
return;
if (!this->client_ptr_) {
RCLCPP_ERROR(this->get_logger(), "Action client not initialized");
if (!this->client_ptr_->wait_for_action_server(std::chrono::seconds(10))) {
"Action server not available after waiting");
this->goal_done_ = true;
return;
auto goal_msg = OdomRecord::Goal();
RCLCPP_INFO(this->get_logger(), "Sending goal");
auto send_goal_options = rclcpp_action::Client<OdomRecord>::SendGoalOptions();
send_goal_options.goal_response_callback =
std::bind(&ActionClientOdomRecorder::goal_response_callback, this,
send_goal_options.feedback_callback =
std::bind(&ActionClientOdomRecorder::feedback_callback, this,
std::placeholders::_1, std::placeholders::_2);
send_goal_options.result_callback = std::bind(
&ActionClientOdomRecorder::result_callback, this, std::placeholders::_1);
auto goal_handle_future =
this->client_ptr_->async_send_goal(goal_msg, send_goal_options);
void ActionClientOdomRecorder::goal_response_callback(
const GoalHandleOdom::SharedPtr &goal_handle) {
if (!goal_handle) {
RCLCPP_ERROR(this->get_logger(), "Goal was rejected by server");
} else {
"Goal accepted by server, waiting for result");
void ActionClientOdomRecorder::feedback_callback(
GoalHandleOdom::SharedPtr,
const std::shared_ptr<const OdomRecord::Feedback> feedback) {
RCLCPP_INFO(this->get_logger(), "Feedback received: %d",
feedback->current_total);
void ActionClientOdomRecorder::result_callback(
const GoalHandleOdom::WrappedResult &result) {
switch (result.code) {
case rclcpp_action::ResultCode::SUCCEEDED:
break;
case rclcpp_action::ResultCode::ABORTED:
RCLCPP_ERROR(this->get_logger(), "Goal was aborted");
return;
case rclcpp_action::ResultCode::CANCELED:
RCLCPP_ERROR(this->get_logger(), "Goal was canceled");
return;
default:
RCLCPP_ERROR(this->get_logger(), "Unknown result code");
return;
RCLCPP_INFO(this->get_logger(), "Result received odom size: %d",
result.result->list_of_odoms.size());
its hpp:
#include <inttypes.h>
#include <iostream>
#include <memory>
#include <string>
#include "custom_interfaces/action/odom_record.hpp"
#include "geometry_msgs/msg/detail/point32__struct.hpp"
#include "rclcpp/rclcpp.hpp"
#include "rclcpp_action/rclcpp_action.hpp"
class ActionClientOdomRecorder : public rclcpp::Node {
public:
const rclcpp::NodeOptions &options = rclcpp::NodeOptions());
void send_goal();
bool is_goal_done() const { return this->goal_done_; };
void activate_send_goal();
private:
rclcpp_action::Client<OdomRecord>::SharedPtr client_ptr_;
bool goal_done_;
bool send_goal_activate_;
void goal_response_callback(const GoalHandleOdom::SharedPtr &goal_handle);
void
feedback_callback(GoalHandleOdom::SharedPtr,
const std::shared_ptr<const OdomRecord::Feedback> feedback);
void result_callback(const GoalHandleOdom::WrappedResult &result);
My CMake:
cmake_minimum_required(VERSION 3.5)
project(wall_following_pkg)
# Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# find dependencies
find_package(rclcpp REQUIRED)
find_package(std_msgs REQUIRED)
find_package(nav_msgs REQUIRED)
find_package(sensor_msgs REQUIRED)
find_package(std_srvs REQUIRED)
find_package(custom_interfaces REQUIRED)
find_package(rclcpp_action REQUIRED)
find_package(geometry_msgs REQUIRED)
if(BUILD_TESTING)
# uncomment the line when a copyright and license is not present in all source files
#set(ament_cmake_copyright_FOUND TRUE)
# uncomment the line when this package is not in a git repo
#set(ament_cmake_cpplint_FOUND TRUE)
endif()
ament_package()
include_directories(include)
add_executable(main_node src/ExploreWorld.cpp src/MoveRobot.cpp src/ScanSubscriber.cpp src/ServiceFindWall.cpp src/ServiceFindWallClient.cpp src/actionClientRecordOdom.cpp)
ament_target_dependencies(main_node custom_interfaces rclcpp std_msgs sensor_msgs rclcpp_action geometry_msgs)
add_executable(action_server_record_odom_node src/actionServerRecordOdom.cpp)
ament_target_dependencies(action_server_record_odom_node rclcpp rclcpp_action custom_interfaces geometry_msgs nav_msgs)
install(TARGETS
main_node
DESTINATION lib/${PROJECT_NAME}
# Install launch files.
install(DIRECTORY
launch
DESTINATION share/${PROJECT_NAME}/
and my package.xml:
<?xml version="1.0"?>
<package format="3">
<name>wall_following_pkg</name>
<version>0.0.0</version>
<maintainer email="adrien_luthy@hotmail.com">user</maintainer>
<buildtool_depend>ament_cmake</buildtool_depend>
<depend>rclcpp</depend>
<depend>std_msgs</depend>
<depend>nav_msgs</depend>
<depend>sensor_msgs</depend>
<depend>std_srvs</depend>
<depend>custom_interfaces</depend>
<depend>rclcpp_action</depend>
<depend>geometry_msgs</depend>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
