Failure to download the key from the keyserver
hello,
I’m not able to download the key from the keyserver, it’s showing : “gpg: keyserver receive failed: Server indicated a failure”
what can I possibly do to overcome this failure?
HI @shahad78 ,
If you are trying to download (and install) ROS and you get this error while downloading, then chances are:
  1. The download server is busy or got disconnected - in this case you can try again later in sometime.
  2. You might be behind a firewall or a VPN - in this case disable firewall and/or VPN and try again.
  3. Your internet may have connectivity issues - in this case restart your modem / router and try again.
If all above fails then Google the same error and search for results on Stack Overflow or Reddit.
@shahad78 ,
Here’s a relevant link: debian - gpg: keyserver receive failed: Server indicated a failure - Unix & Linux Stack Exchange
First link on Google - copy-pasted “gpg: keyserver receive failed: Server indicated a failure” and searched.
BY follow the link that attached by @girishkumar.kannan I solve the problem:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 421C365BD9FF1F717815A3895523BAEEB01FA116
Thanks.
