Course: Linux for Robotics, final project rosject “Linux Basics Real Robot Project”
Booked slots: 24 Nov 2026, 1:00 AM IST and about 1:00 PM IST
Problem: After connecting to the real robot, the robot does not move with the on-screen joystick, teleop_twist_keyboard, or my bash scripts. The camera streams are LIVE.
What I checked:
/cmd_vel_safeshows correct velocity commands from my scripts/teleop.ros2 topic info /odom -vshows 2 publishers (serial_motor_driver and ros_bridge), butros2 topic echo /odomreceives nothing, even with--qos-reliability best_effort.ros2 topic hz /scanworks at ~10 Hz, so the lidar is fine.- RViz shows Global Status: Error, and robot model errors (fastbot_description package not found).
- Same scripts work correctly in the Gazebo simulation.
Takavarasha (instructor) said the issue was fixed, but it is still not working. Could someone from the team please check the motor driver (serial_motor_driver) on the FastBot?
Screenshots attached.
