File Explorer Blank Fix
Not sure if anyone else had this problem but when loading Unit 2 for Python 3 for Robotics I had an issue where my file explorer was blank without me changing anything. I right clicked on the file explorer and created a blank file and all the folders showed up again. Hopefully this helps anyone with the same issue.
Hi @ARodas ,
The most common solutions for this glitch is discussed here:
Your fix, of course, was one of them discussed.
