Finished 99% of the course but can't get to 100% because of failed Services Quiz
I have recently finished the ROS2 C++ basics course up to 99%, but I can’t get to 100% because I exhausted my 5 attempts. Unfortunately, I did not correct my errors properly or seek help in time. What should I do? Does the quiz have to be completed to finish the course? Do I have to re-do the whole course again?
@ven011
We could have assigned you a few more trials to complete the quiz if you had not viewed the solution.
That said, I have manually updated your completion to 100% in the backend, since you have technically completed the course. Please note that the “completion mark” will remain unchecked for the Services quiz because you did not score at least 5 in the quiz.
I see you have completed a couple of courses already. Keep pushing your ROS learning!
Thank you very much!
