For some reason my task 3 wont pass
I get the points for my get_laser_readings but not main does anyone have any ideas why?
import time
class ExamControl:
        self.rc = RobotControl()
    def get_laser_readings(self):
        #returns left and right laser readings
        left = self.rc.get_laser(719)
        right = self.rc.get_laser(0)
        return left, right
    def main(self):
        #behavior
        left, right = self.get_laser_readings()
        while left != float("inf") and right != float("inf"):
            self.rc.move_straight()
        #time.sleep(1)
        self.rc.stop_robot()
@thunderbootyclap
def init(self):
This should been as below. You need to add __before and after init to be considered a constructor of the class.
Also, there should have been an indent after class ExamControl::
Your code:
class ExamControl:
def init(self):
def main(self):
    #code
This should have been as below with an indent (click on tab once):
class ExamControl:
    def main(self):
    #code
@Joseph1001
Those are formatting errors on my part when asking the question, in my task3.py I do have init and an indent for the class. For some reason the double underscores are bolding init
I just formatted the code to see it better.
Next time, for formatting, you can use the next three symbols (but without space) rather than “>” to format the code.
# the code here,
    # with correct identation
Hi @thunderbootyclap ,
The problem with your script is the same that happened with other student pointed below.
Please follow the link below to better understand the explanation.
Thank you for the markup and help with my code, that was the issue. More specifically the while loop with and as described by this post
