From ardrone_autonomy.msg import Navdata. No module named msg
I am trying to complete the Drone Programming Course, Unit 4.
After downloading the package eYSIP-2017_Navigation-in-Indoor-Environments-using-drone, I have been trying to run a python script (follow_trajectory.py) and got the error:
(from ardrone_autonomy.msg import Navdata ImportError: No module named msg)
You can see the generated error in the screenshots, and the changes made inside CMakeLists.txt and package.xml
Do I need to add something else in these files?
Screenshot 2022-02-27 at 02.57.27
Screenshot 2022-02-27 at 02.57.52
Screenshot 2022-02-27 at 03.02.11
Screenshot 2022-02-27 at 02.58.07[img]
Screenshot 2022-02-27 at 02.58.26
Any help would be appreciated. Thank you
Have you compiled and sourced the workspace?
cd ~/catkin_ws
rm -rf build/ devel/
catkin_make
source devel/setup.bash
In addition, you need to run source devel/setup.bash on any shell where you want to run the program.
Hello @VT71 ,
Do you have this ardrone_autonomy package in your workspace? if not, you should download it with the following command:
git clone https://github.com/AutonomyLab/ardrone_autonomy.git
Dear bayodesegun,
Thank you for your reply.
Yes, I have tried that, same result
Dear albertoezquerro,
I have typed: roscd ardrone_autonomy
And this location was shown: /opt/ros/kinetic/share/ardrone_autonomy
I think this is the problem: your package.xml file does not have the right entries.
What I would recommend here is that you recreate that package and specify all the dependencies at the point of creation. This creates the correct entries for you in package.xml and the required entries in CMakeLists.txt.
If you can’t recreate the package, then please check that the right entries are in those files. For example, the entries in your package.xml for ardrone_autonomy are different from the ones added when the dependency was added at package creation. TIP: you can create a dummy package with the dependency you want to add later to see the lines that should be added for CMakeLists.txt and package.xml.
For example, these entries were generated when I specified rospy and ardrone_autonomy as dependencies from the outset:
catkin_create_pkg drone_application rospy ardrone_autonomy
CMakeLists.txt
project(drone_application)
  ardrone_autonomy
  rospy
# catkin_python_setup()
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a exec_depend tag for "message_runtime"
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
# add_service_files(
#   FILES
#   Service1.srv
#   Service2.srv
# add_action_files(
#   FILES
#   Action1.action
#   Action2.action
# generate_messages(
#   DEPENDENCIES
#   std_msgs  # Or other packages containing msgs
##   * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
##   * add "dynamic_reconfigure" to
##   * uncomment the "generate_dynamic_reconfigure_options" section below
##     and list every .cfg file to be processed
#   cfg/DynReconf1.cfg
#   cfg/DynReconf2.cfg
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES drone_application
#  CATKIN_DEPENDS ardrone_autonomy rospy
#  DEPENDS system_lib
## Build ##
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/drone_application.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/drone_application_node.cpp)
#   ${catkin_LIBRARIES}
## Install ##
#   scripts/my_python_script
#   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
# install(FILES
#   # myfile1
#   # myfile2
#   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_drone_application.cpp)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
# catkin_add_nosetests(test)
package.xml
<?xml version="1.0"?>
<package format="2">
  <name>drone_application</name>
  <version>0.0.0</version>
  <description>The drone_application package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/drone_application</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <build_depend>ardrone_autonomy</build_depend>
  <build_export_depend>ardrone_autonomy</build_export_depend>
  <exec_depend>ardrone_autonomy</exec_depend>
  <export>
  </export>
</package>
test_import.py
nav = Navdata()
print(nav)
Terminal 1
user:~/catkin_ws$ rm -rf build/ devel/
user:~/catkin_ws$ catkin_make
user:~/catkin_ws$ source devel/setup.bash
user:~/catkin_ws$ chmod +x src/drone_application/src/test_import.py
user:~/catkin_ws$ rosrun drone_application test_import.py
header:
  seq: 0
  stamp:
    secs: 0
    nsecs:         0
  frame_id: ''
batteryPercent: 0.0
state: 0
magX: 0
magY: 0
magZ: 0
pressure: 0
temp: 0
wind_speed: 0.0
wind_angle: 0.0
wind_comp_angle: 0.0
rotX: 0.0
rotY: 0.0
rotZ: 0.0
altd: 0
vx: 0.0
vy: 0.0
vz: 0.0
ax: 0.0
ay: 0.0
az: 0.0
motor1: 0
motor2: 0
motor3: 0
motor4: 0
tags_count: 0
tags_type: []
tags_xc: []
tags_yc: []
tags_width: []
tags_height: []
tags_orientation: []
tags_distance: []
tm: 0.0
Dear bayodesegun,
I have tried to recreate a dummy package and the only different lines in that package was that it contained:
After adding this lines, I could not run catkin make, because of the following errors, so I deleted them:
Please find my whole CMakeLists.txt file, and also package.xml
## Add support for C++11, supported in ROS Kinetic and newer
# add_definitions(-std=c++11)
  roscpp
  rospy
  std_msgs
  message_generation
  actionlib_msgs
  actionlib
  ardrone_autonomy
##   * add a build_depend and a run_depend tag for each package in MSG_DEP_SET
##     * add a run_depend tag for "message_runtime"
 add_message_files(
   FILES
   pid_error.msg
#   FILES
#   Service1.srv
#   Service2.srv
add_action_files(
  FILES
  move.action
 generate_messages(
   DEPENDENCIES
   actionlib_msgs
   std_msgs
catkin_package(
  CATKIN_DEPENDS
  message_runtime
  actionlib_msgs
  ardrone_autonomy
##   * add a build_depend and a run_depend tag for "dynamic_reconfigure"
## INCLUDE_DIRS: uncomment this if you package contains header files
catkin_package(
#  CATKIN_DEPENDS roscpp rospy std_msgs
## Build ##
# include_directories(include)
## Install ##
# install(PROGRAMS
## Mark executables and/or libraries for installation
# install(TARGETS ${PROJECT_NAME} ${PROJECT_NAME}_node
# install(FILES
#   # myfile1
#   # myfile2
## Testing ##
# endif()
# add_executable(octmap_publisher src/octmap_publisher.cpp)
# target_link_libraries(octmap_publisher ${catkin_LIBRARIES})
<package>
  <!-- Example:  -->
  <maintainer email="ros@todo.todo">ros</maintainer>
  <!-- Example: -->
  <!-- Example: -->
  <!-- The *_depend tags are used to specify dependencies -->
  <!-- Examples: -->
  <!-- Use run_depend for packages you need at runtime: -->
  <!--   <run_depend>message_runtime</run_depend> -->
  <build_depend>actionlib</build_depend>
  <build_depend>actionlib_msgs</build_depend>
  <run_depend>actionlib</run_depend>
  <run_depend>actionlib_msgs</run_depend>
  <run_depend>roscpp</run_depend>
  <run_depend>rospy</run_depend>
  <run_depend>std_msgs</run_depend>
  <run_depend>ardrone_autonomy</run_depend>
  <export>
  </export>
</package>
The package: eYSIP-2017_Navigation-in-Indoor-Environments-using-drone
Has to be downloaded in Unit 4: Programming Drones.
Do you have a version of this package that works, without errors?
Because in the tutorial, there are no steps, to make any changes to this package.
Thank you for your help
After adding those lines, please remove the <run_depends> lines and try again. Really, I would recommend you create a new package and add all those dependencies at the time of creation. Adding new dependencies by hand can be tricky.
You can create a new package by moving the original package into catkin_ws, then create a package with the same name in catkin_ws/src, and move over the source files in the old package one by one.
We’ll look into this ASAP.
Hello @VT71 ,
Please download the following repository into your workspace: git clone Bitbucket
It contains an specific version of the ardrone_autonomy package. Also, remember to compile your workspace again. Let me know if this fixes the issue.
I have rebuilt the package, selecting all the dependent packages at the beginning but I still get errors regarding:
I have also installed another version of ardrone_autonomy (Bitbucket)
package.xml file:
  <!-- Example:  -->
  <!-- Example: -->
  <!-- Example: -->
  <!-- Examples: -->
  <build_depend>aruco_mapping</build_depend>
  <build_depend>moveit_msgs</build_depend>
  <build_depend>message_runtime</build_depend>
  <build_export_depend>actionlib</build_export_depend>
  <build_export_depend>actionlib_msgs</build_export_depend>
  <build_export_depend>aruco_mapping</build_export_depend>
  <build_export_depend>moveit_msgs</build_export_depend>
  <build_export_depend>roscpp</build_export_depend>
  <exec_depend>actionlib</exec_depend>
  <exec_depend>actionlib_msgs</exec_depend>
  <exec_depend>aruco_mapping</exec_depend>
  <exec_depend>moveit_msgs</exec_depend>
  <exec_depend>message_generation</exec_depend>
  <export>
  </export>
</package>
CMakeLists.txt file:
  actionlib
  actionlib_msgs
  ardrone_autonomy
  aruco_mapping
  message_generation
  message_runtime
  moveit_msgs
  roscpp
  rospy
  std_msgs
add_message_files(
   FILES
   pid_error.msg
#   FILES
#   Service1.srv
#   Service2.srv
add_action_files(
	FILES
  	move.action
generate_messages(
	DEPENDENCIES
   	actionlib_msgs   moveit_msgs   std_msgs
catkin_package(
	CATKIN_DEPENDS actionlib actionlib_msgs ardrone_autonomy aruco_mapping message_generation message_runtime moveit_msgs roscpp rospy std_msgs
	DEPENDS system_lib
## Build ##
# include
## Install ##
# install(FILES
#   # myfile1
#   # myfile2
## Testing ##
# endif()
Would it be possible to upload on Bitbucket, a working version of:
Thank you
Hi bayodesegun,
I think the issue might be because of the package ardrone_autonomy, I have found the same problem online, regarding importing from ardrone_autonomy.msg.
However, the package version from Bitbucket did not solve that.
I just checked your files and didn’t find the drone_application package there - where did you create it? Locally?
Also, when you recreate everything, you need to remove build and devel folders before you recompile:
cd ~/catkin_ws
catkin_make
The package is located in my rosject called: Test Rosject. The workspace is simulation_ws
I get the error when running:
rosrun drone_application move_to_waypoint.py _real_drone:=false _aruco_mapping:=false
Please next time to save time, please specify critical details like this. I thought it was in the course all along!
Now that it’s a rosject, please try the following:
  • Remove all packages you have created in simulation_ws:
cd ~/simulation_ws
# Remove the package folders
  • Please create all your packages in catkin_ws.
  • The ardrone_autonomy package may not be available as it was in the course environment, so please use the repository provided by @albertoezquerro. You should clone it to catkin_ws/src.
cd ~/catkin_ws/src
git clone repo_https_url
  • Compile and source the workspace:
cd ~/catkin_ws
catkin_make
  • Create the drone_application package afresh in catkin_ws/src.
  • Compile and source the workspace again.
Let us know how it goes.
Dear bayodesegun,
I think, recreating the packages inside catkin_ws solved the issue.
