HI, doing the exercise 4.2 I got the solution with a function called leerlaser() which works fine and I tried a second solution by leerlaser2(). here the code:
ob1 = RobotControl()
def leerlaser(val1, val2, val3):
dist1 = ob1.get_laser_summit(val1)
dist2 = ob1.get_laser_summit(val2)
dist3 = ob1.get_laser_summit(val3)
return [dist1, dist2, dist3]
def leerlaser2(vals):
for i in vals:
print (i)
j=0
dist[j]= ob1.get_laser_summit(vals[j])
j=j+1
return dist
distancias = leerlaser(10, 100, 500)
print (distancias[0])
print (distancias[1])
print (distancias[2])
valores = (100, 300, 460)
distancias = leerlaser2(valores)
So when running the code, leealser() works and when executing leerlaser2() I got:
100
File "function_2.py", line 33, in <module>
File "function_2.py", line 17, in leerlaser2
NameError: global name 'dist' is not defined
I tried defining dist as global but still not working… I do not know where the problem is.
Thanks.
