Gazebo sim bridge not working properly
i have followed the gazebo sim course and now want to add camera to my robot and have done that successfully but after using the bridge there are no messages generated on the topic
Following is the camera link and joint code in the urdf
<joint name="camera_joint" type="fixed">
        <parent link="base_link"/>
        <child link="camera_link"/>
        <origin xyz="0.305 0 0.08" rpy="0 0 0"/>
    </joint>
    <link name="camera_link">
        <pose>0.05 0.05 0.1 0 0 0</pose>
        <inertial>
            <mass value="0.5" />
            <inertia ixx="0.000252666666667" ixy="0" ixz="0" iyy="0.000252666666667" iyz="0" izz="0.0005"/>
        </inertial>
        <collision name="collision">
            <geometry>
                <box size="0.1 0.1 0.1"/>
            </geometry>
        </collision>
        <visual name="visual">
            <geometry>
            </geometry>
        </visual>
        <sensor name="camera" type="camera">
            <camera>
                <horizontal_fov>1.047</horizontal_fov>
                <image>
                    <width>320</width>
                    <height>240</height>
                </image>
                <clip>
                    <near>0.1</near>
                    <far>100</far>
                </clip>
            </camera>
            <always_on>1</always_on>
            <update_rate>30</update_rate>
            <visualize>true</visualize>
            <topic>camera</topic>
        </sensor>
    </link>
and this are the arguments of bridge in the launch file
arguments=[
            "/clock" + "@ rosgraph_msgs/msg/Clock" + "[ignition.msgs.Clock",
            "/cmd_vel" + "@ geometry_msgs/msg/Twist" + "@ ignition.msgs.Twist",
            "/tf" + "@ tf2_msgs/msg/TFMessage" + "[ignition.msgs.Pose_V",
            "/odom" + "@ nav_msgs/msg/Odometry" + "[ignition.msgs.Odometry",
            "/scan" + "@ sensor_msgs/msg/LaserScan" + "[ignition.msgs.LaserScan",
            "/imu" + "@ sensor_msgs/msg/Imu" + "[ignition.msgs.IMU",
            "/camera" + "@ sensor_msgs/msg/Image" + "[ignition.msgs.Image",
i am also getting the follwing warning on terminal
[ruby $(which ign) gazebo-1] libEGL warning: egl: failed to create dri2 screen
