Gazebo unresponsive to service call
I’m having an issue with task 2. I’ve got the drone moving, landing and taking off, and launch file works fine too. However, when calling the service /my_service through the command line, the method take_off() is called, but gazebo does not react. Is this an error in gazebo, or my coding?
Thank you.
forward_motion.py
import time
class RobotControl(object):
        # creates publishers
        self.pub_cmd_vel = rospy.Publisher("/cmd_vel", Twist, queue_size=10)
        self.pub_take_off = rospy.Publisher("/drone/takeoff", Empty, queue_size=10)
        self.pub_land = rospy.Publisher("/drone/land", Empty, queue_size=10)
        # creates messages to publish
        self.move = Twist()
        self.takeoff = Empty()
        self.land = Empty()
        self.rate = rospy.Rate(10)
    def take_off(self):
        rospy.loginfo('Taking off...')
        self.pub_take_off.publish(self.takeoff)
        time.sleep(5)
        rospy.loginfo("The quadcopter finished taking off")
    def move_forward(self):
        rospy.loginfo("Moving forward...")
        self.move.linear.x = 1
        self.move.angular.z = 0
        self.pub_cmd_vel.publish(self.move)
        time.sleep(5)
        rospy.loginfo("The quadcopter finished moving forward")
    def stopping(self):
        rospy.loginfo('Stopping...')
        self.move.linear.x = 0
        time.sleep(5)
        rospy.loginfo("The quadcopter finished stopping")
    def landing(self):
        rospy.loginfo('Landing...')
        self.pub_land.publish(self.land)
        time.sleep(5)
        rospy.loginfo("The quadcopter finished landing")
if __name__ == '__main__':
    name_of_node = "forward_motion"
    rospy.init_node(name_of_node)
    rospy.loginfo("Node initiated: %s", name_of_node)
    rc = RobotControl()
    time.sleep(2)
    rate = rospy.Rate(0.5)
    ctrl_c = False
    def shutdownhook():
        global ctrl_c
        rospy.loginfo("Shutdown time!")
        ctrl_c = True
    rospy.on_shutdown(shutdownhook)
    while not ctrl_c:   # while not true
        rospy.loginfo("Main loop...")
        rc.take_off()
        rc.move_forward()
        rc.stopping()
        rc.landing()
        ctrl_c = True
motion_service.py
from std_srvs.srv import EmptyResponse, Empty as EmptyServiceMsg
from forward_motion import RobotControl
def my_callback(request):
    rospy.loginfo("The Service to start the drone has been called")
    rc = RobotControl()
    rc.take_off()
    rospy.loginfo("Finished service")
    response = EmptyResponse()
    return response
rospy.init_node('service_move_drone')
my_service = rospy.Service('/my_service', EmptyServiceMsg , my_callback)
rospy.loginfo("Service /my_service Ready")
rospy.spin() # mantain the service open.
Try looping the command:
for i in range(10):
publishing in topics sometimes fails the first time you publish.
Great. Thanks! It worked.
Say you have several topics in a program, how would one go about writing a function/method to publish once into all topics, without actually causing the robot to act on it? Would it make sense to put such a function as the first call in the program once everything is set up, or should it be called EVERY time a publish is wanted?
@torpanvil.
Bravo!!!
This is a great way to do it, and I’m going to make this a wiki for everyone!
Oh great! I must be getting better at this! :sweat_smile:
