Getting an error while creating a service message
I receive this error message when I run
catkin_make
This is the CMakeLists.txt file:
project(rosject)
rospy
std_msgs
message_generation
#Generate services in the ‘srv’ folder
add_service_files(
FILES
FindWall.srv
generate_messages(
DEPENDENCIES
std_msgs
catkin_package(
CATKIN_DEPENDS
rospy
include_directories(
${catkin_INCLUDE_DIRS}
Blockquote
It is complaining at the line where generate_messages() is, right below where you added your service. Assuming you have everything correct there and that you have added
to package.xml, then maybe try creating the whole package again
@roalgoal I believe I did as you suggested but the error still shows.
from rosject.srv import Findwall, FindwallResponse
and under generate_msgs:
generate_messages(
   DEPENDENCIES
   std_msgs
   geometry_msgs
   sensor_msgs
type or paste code here
I recreated the entire package again and I still get the same error
@roalgoal I somehow fixed it. Everything seemed alright in the CMakelists.text and package.xml files. I had an issue in the service_message.srv file. I dont know what exactly was my mistake, but I hope you can help me understand.
bool wallfound
This was the original .srv message I had typed.
I replaced it with another message from a tutorial with
int32 duration    # The time (in seconds) during which BB-8 will keep moving in circles
bool success      # Did it achieve it?
After running catkin_make it worked. Can you please explain why?
Thank you for your help
@mamojiz97 ,
I think I understand your problem exactly!. I believe you copy-pasted the service message as-is from the instructions/notebook? That is where the problem is…
In the notebook the message is typed as
FindWall.srv
bool wallfound
But instead, it should actually read: REPLACE YOUR SRV FILE CONTENTS WITH THIS
   # blank line here representing Empty service message request
bool wallfound
I believe you included the line FindWall.srv in your srv file which the CMake could not understand the data type of the variable. Therefore, you got that error.
Please change your service message to the modified lines above. This should fix the issue.
Let me know if this helped!
@girishkumar.kannan
I did not actually, copy-pasted the message exactly. I did not include FindWall.srv in my srv file. Just like you said I left a blank space and then wrote the the response message of the srv file.
I received the same error message for this as well. I think it was something to do with the way I typed maybe in the indentations etc. Honestly I don’t think that was the case though.
Thank You
Hey @mamojiz97 ,
I think I found the issue…
The message imports in Python are CASE–SENSITIVE.
To Summarize:
  1. Replace from rosject.srv import Findwall, FindwallResponse with from rosject.srv import FindWall, FindWallResponse
  2. Change contents of FindWall.srv file as below:
bool wallfound
  1. Make sure your file formatting is set to ASCII / UTF-8 in your computer and does not use any fancy unicode characters.
  2. Last resort - if all above fails, re-create the package from scratch.
Let me know if this worked!
