Getting data from subscribers
Hi, im trying to get the data from a subscriber, and the use it to determinate the movement of the robot. But, when the gets to the while, it tells me that d_laser.ranges is size 0 and i exceed the index. I dont know where the problem is.
d_laser=LaserScan()
def callback(datos_laser):
global d_laser
d_laser.ranges=datos_laser.ranges
rospy.init_node(‘topics_quiz_node’)
salida=rospy.Publisher(‘/cmd_vel’,Twist,queue_size=1)
entrada=rospy.Subscriber(‘/kobuki/laser/scan’,LaserScan,callback)
velocidad=Twist()
velocidad.linear.x=0
velocidad.angular.z=0
fm=rospy.Rate(2)
if d_laser.ranges[len(d_laser.ranges)//2]>1:
    velocidad.linear.x=1
    salida.publish(velocidad)
else:
    velocidad.angular.z=0.5
    if d_laser.ranges[len(d_laser.ranges)-1]<1:
    elif d_laser.ranges[1]<1:
        velocidad.angular.z=-0.5
fm.sleep()
Welcome to the world of programming, where nothing happens as/when expected, and you have to check if/when!
You need to put some print/logging statements within your code to inspect critical variables. For instance, you should inspect the datos_laser variable to see if/when something actually gets there.
