hello, this is Irfan… I just finished the code foundation for ROS exam and got 8.25 grade. After making some changes in the task that failed, now the grade is 9. I just want to know whether the grade on accomplishment section will update. (because it still shows 8.25 instead of 9)
No, the certificate is locked once generated. If there’s a cogent reason to modify it, we can reset it manually.
In this case, you don’t need to bother about the grade since both are passing grades and are not shown publicly. The most important thing is that you already have the knowledge.
