Gradebot issue in basic exam
my EXAM for drone is done. the drone is moving in square but it’s noted as it’s not moving in square.
In order to get help faster, you need to give as much details as possible:
  • Show the gradebot output screenshot
  • Show how you implemented the “move in square”
  • Show any other information that might help to understand the issue
it’s moving in a square only but i’m getting this on grade bot
I see you were able to figure this out and scored 10/10. Good job :+1:.
Most likely, the square you were making was not big enough or you were publishing to the wrong topic, as Gradebot suggested.
yeah solved, thanks for replying :blush:
