Grader failed while Testing on IDE run perfectly (Already checked file names)
Hi @Hannah_Vu ,
Welcome to this Community!
One of the solution from people who had the same issue was to do the following:
  1. Compile the packages
  2. Verify if your package works as intended (by manually executing your package)
  3. If your package works correctly then go to step 4 and 5 else start over.
  4. Delete your build, install and log folders from ros2_ws
  5. Without building again, that is, without doing colcon build ..., send it to autograder / gradebot.
Hope this helps. Let me know if this does not work.
Regards,
Girish
EDIT: Here is the link to the solution explained above: Services Quiz. Gradebot Fails to compile the package. How fix it? - #12 by oleg.a.kuvaev
