I am having issues with the exam for ROS Navigation, the grading has been stuck after the check “action topics found” for more then one hour. Have tried resubmitting and also different browsers.
Were you able to test the package successfully before submitting it to the grader?
Do you have a process running in one of your terminals? Make sure you kill them all.
Finally, make sure that your code doesn’t have an infinite loop that might cause an error in the grader.
Hi, thanks for the feedback.
I tried it now, without making any changes, and worked.
