I was running rviz in a separate tab, yet now and then, when i come back to shell, the graphical window keeps popping up. Can you turn off this feature?
Hi @Joseph1001 ,
Thank you for reporting, the pop-up should only happens when a graphical window is detected in the backgrounds for the first time.
Could you share which command you have run in the shell to raise this persistent pop-up behavior?
I was running rviz, but in a separate window.
(Note that i am seeing less of this error lately.)
I understand, since you have it opened in another window/tab, the pop-up is not helpful at all.
I’m setting up priority to this matter.
Thank you for your patience and for reporting.
I’ll keep you updated about the next improvements soon
Thanks for looking into this and fast action.
This topic was automatically closed after 2 days. New replies are no longer allowed.
