Guidance needed in exercise 5.2
Hi, i am totally new to ROS. In exercise 5.2, we are required to make a new package my_motion_scripts. I tried running it and failed. May i know the exact method to make this package? Would be useful to include in the exercise as well for newbies like myself.
in my launch file “planning.launch”:
<node name = "planning_scripts_node_launch" pkg = "my_motion_scripts" type = "planning_script.py" output = "screen">
</node>
in my python file “planning_script.py”
import sys
import copy
import moveit_commander
import moveit_msgs.msg
import geometry_msgs.msg
moveit_commander.roscpp_initialize(sys.argv)
rospy.init_node(‘move_group_python_interface_tutorial’, anonymous=True)
robot = moveit_commander.RobotCommander()
scene = moveit_commander.PlanningSceneInterface()
group = moveit_commander.MoveGroupCommander(“arm”)
display_trajectory_publisher = rospy.Publisher(‘/move_group/display_planned_path’, moveit_msgs.msg.DisplayTrajectory, queue_size=1)
pose_target = geometry_msgs.msg.Pose()
pose_target.orientation.w = 1.0
pose_target.position.x = 0.96
pose_target.position.y = 0
pose_target.position.z = 1.18
group.set_pose_target(pose_target)
plan1 = group.plan()
rospy.sleep(5)
moveit_commander.roscpp_shutdown()
Hi @zulqarnain.abdul.halil ,
Welcome to this Community!
Looking at the picture of your IDE setup, the project folder my_motion_scripts does not seem to contain CMakeLists.txt file and package.xml file.
Are you sure you created this package using catkin_create_pkg command?
If you did not create the package that way, then you need to refer how to create a package in ROS1 (Noetic) and then implement that here.
Currently your my_motion_scripts is not a ROS package, it is just a regular folder with codes in it.
This will not work.
I created the package using catkin_create_pkg command as suggested at it works. Thanks!
Best Regards
Zulqarnain
Glad to know that your issue is now resolved.
Please mark the post as solution so this thread can be closed.
