Custom header files doest seems to be backed up. They would have to be rebuilt every time after reloading the session. I normally had to comment out building the src files to create these header files first and rebuild the source files again.
Its a workable work around but it would be helpful to have the custom header files backed up as well.
/home/user/catkin_ws/src/services_quiz/src/bb8_move_custom_service_client.cpp:2:51: fatal error: services_quiz/BB8CustomServiceMessage.h: No such file or directory
Thanks
Hi @cshreyastech,
Sorry for the trouble!
Please help us to understand better
- are you talking about having to recreate the files or having to rebuild them?
- as far as I understand, you shouldn’t have to create header files for your custom messages manually - are you do this manually? If so, why?
- where are you putting your custom header files? Any file you put in
catkin_ws/src should be backed up.
Hi @bayodesegun,
My apologies for being unclear.
catkit workspace had to be rebuild to generate custom header file for every new session. They are not being backup. Rest of the source files are being backup properly. no issues with them.
I dont create header file manually. I just let the compile take care of it.
Steps to reproduce and fix:
- attempt to build my workspace this morning (fresh session)
user:~/catkin_ws$ catkin_make -DCATKIN_BLACKLIST_PACKAGES=“my_package;service_server_pkg;service_client_pkg;topic_publisher_pkg;topic_subscriber_pkg;my_custom_srv_msg_pkg;action_client_pkg;”
[ 7%] Building CXX object services_quiz/CMakeFiles/move_bb8_in_square_custom_client.dir/src/bb8_move_custom_service_client.cpp.o
- comment out compile source files from CMakeList.txt in services_quiz to generate BB8CustomServiceMessage.h and rebuild
# add_executable(move_bb8_in_square_custom_server src/bb8_move_custom_service_server.cpp)
# add_dependencies(move_bb8_in_square_custom_server ${move_bb8_in_square_custom_server_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
# target_link_libraries(move_bb8_in_square_custom_server
# ${catkin_LIBRARIES}
# add_executable(move_bb8_in_square_custom_client src/bb8_move_custom_service_client.cpp)
# add_dependencies(move_bb8_in_square_custom_client ${move_bb8_in_square_custom_client_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
# target_link_libraries(move_bb8_in_square_custom_client
after rebuild, head file created
user:~/catkin_ws$ find -name BB8CustomServiceMessage.h
./devel/include/services_quiz/BB8CustomServiceMessage.h
step 3) rebuild, uncommenting the CMakelists.txt to compile the source files of services_quiz
all source file compiled successfully as the depended header files are available
[ 0%] Built target _services_quiz_generate_messages_check_deps_BB8CustomServiceMessage
[ 15%] Linking CXX executable /home/user/catkin_ws/devel/lib/services_quiz/move_bb8_in_square_custom_client
[ 15%] Built target move_bb8_in_square_custom_client
Scanning dependencies of target move_bb8_in_square_custom_server
[ 23%] Building CXX object services_quiz/CMakeFiles/move_bb8_in_square_custom_server.dir/src/bb8_move_custom_service_server.cpp.o
[ 30%] Linking CXX executable /home/user/catkin_ws/devel/lib/services_quiz/move_bb8_in_square_custom_server
[ 30%] Built target move_bb8_in_square_custom_server
[ 46%] Built target topics_quiz_node
[ 53%] Built target services_quiz_generate_messages_cpp
[ 69%] Built target services_quiz_generate_messages_py
[ 84%] Built target services_quiz_generate_messages_eus
[ 92%] Built target services_quiz_generate_messages_nodejs
[100%] Built target services_quiz_generate_messages_lisp
This has to be done for every new session. In short, it seems devel directory doest get backed up and they have the header files.
@cshreyastech,
Yes, the build and devel folders are not saved, but that’s not the problem, because while loading your environment we recompile the workspace for you.
The problem is that you have to comment/uncomment some lines in CMakeList.txt in order to get your workspace compiled - you shouldn’t have to do this
The problem that has to be fixed here is that you should not have to comment or uncomment to have things working. Could you please tell us why are you doing that:
- Do you have some lines that really shouldn’t be there?
- Do you have some lines with wrong configurations (like wrong file or directory name)?
I dont think I have anything missing in CMakeList.txt as of my knowledge . I think I am missing some dependencies. Here is the file. Can you kindly review it?
project(services_quiz)
message_generation
roscpp
std_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
add_service_files(
FILES
BB8CustomServiceMessage.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES services_quiz
# CATKIN_DEPENDS message_generation roscpp std_msgs
# DEPENDS system_lib
${catkin_LIBRARIES}
${catkin_LIBRARIES}
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/services_quiz.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/services_quiz_node.cpp)
## Install ##
# install(PROGRAMS
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_services_quiz.cpp)
# endif()
# catkin_add_nosetests(test)
Thanks
I will play around with it this week. I will see if can figure it out myself first.
Thanks,
Shreyas
Are you able to figure this out yet @cshreyastech?
@bayodesegun
I tried altering dependencies both in Cmakelist and in the xml file. I still run into same issue. I am sure I am missing some dependencies. I am not sure about that yet.
@cshreyastech You need to examine your CMakeList.txt according to the instructions and examples given, and then make the necessary corrections.
@bayodesegun @cshreyastech
I am getting this same issue exactly. And it looks like we were on similar portions of the tutorial.
I encountered this issue for the first time after making no edits to what I was working on. I had a working, compiled workspace, I logged out and when I logged back in I encountered this issue when I went to run ‘catkin_make’.
@rmmilner @cshreyastech
Problems like this usually have to do with not editing CMakeLists.txt and package.xml correctly. Any small type or wrong name could ruin things. Here are some hints:
- Add the necessary dependencies at during package creation. E,g
catkin_create_pkg my_pack rospy adds roscpp as a dependency. The examples and the exercises will tell you what dependency to add. The right entries will be created for your in CMakeLists.txt and package.xml.
- Avoid copy/pasting
CMakeLists.txt and package.xml. Rather, edit the ones automatically created accordingly.
- Remember that you need to setup the C++ source file in
CMakeLists.txt.
- Setup
CMakeLists.txt and package.xml to recognize custom messages, following the examples and instructions given carefully.
@cshreyastech
Are you able to get past this error?
I made no edits to any file to fix this issue. I left the project, went to another module and then returned and that fixed it.
yes, I could fix it long time ago. I dont quite remember the fix. I think its about adding correct dependency.
message_generation
roscpp
std_msgs
# FILES
# Message1.msg
# Message2.msg
add_service_files(
FILES
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
catkin_package(
${catkin_LIBRARIES}
${catkin_LIBRARIES}
## Build ##
# include
## Install ##
# install(PROGRAMS
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# endif()
@bayodesegun, this is the working version.
@bayodesegun I looked at this post, changed my makefile to mirror this and I am still getting the same error.
@rmmilner,
I suppose you got it working before now?
What I would advise:
- Go over the steps given in the notebook again to be sure there’s nothing missed.
- Run
rm -rf build/ devel/ from catkin_ws.
- Run
catkin_make and then source devel/setup.bash.
If you are still getting any errors, please give more details about it.
