Hello, i’m trying to get the robot to move in a square, but I cant seem to make it work, as when I call the service, the robot moves only in one direction and the process finishes, ignoring the rest of the movements I have coded it to do. My code is below, if anyone could help me I would appreciate it a lot.
from services_quiz.srv import BB8CustomServiceMessage, BB8CustomServiceMessageResponse
from math import pi
def my_callback(request):
my_response = BB8CustomServiceMessageResponse()
sides = request.side
i = request.repetitions+1
j = 0
while j < 4:
straight(sides)
rotate()
j+=1
move.linear.x = 0.0
pub.publish(move)
my_response.success = True
return my_response.success
def straight(sides):
wait_time = float(sides/10)
move.linear.x = 0.2
pub.publish(move)
rospy.sleep(wait_time)
move.linear.x = 0.0
pub.publish(move)
def rotate():
move.angular.z = 90*2*pi/360
pub.publish(move)
rate.sleep()
move.angular.z = 0
pub.publish(move)
rate.sleep()
rospy.init_node('bb8_square')
pub = rospy.Publisher('/cmd_vel', Twist, queue_size=3)
move = Twist()
my_service = rospy.Service('/move_bb8_in_square_custom', BB8CustomServiceMessage , my_callback)
rospy.wait_for_service('/move_bb8_in_square_custom')
rate = rospy.Rate(10)
rospy.spin()
Hi @d.zablah, welcome to the community…
The use of rate.sleep()
in your rotate()
function is causing this issue,
rospy.Rate
convenience class is used to maintaining a particular rate for a loop and isn’t the most appropriate method for your current application.
I replaced rate.sleep()
with rospy.sleep(2)
and your bb8 was taking turns just fine.
Happy learning …!!
Thanks for the reply! I have fixed it and now it turns nicely. However, no matter how many repetitions I do it wont go past the first square. Here is the updated code:
reps = request.repetitions
moveBB8(reps, sides)
wait_time = float(sides/2)
move.linear.x = 0.3
pub.publish(move)
move.linear.x = 0.0
pub.publish(move)
def rotate():
move.angular.z = 0.2
pub.publish(move)
rospy.sleep(8)
move.angular.z = 0
pub.publish(move)
rospy.sleep(1)
def moveBB8(reps, sides):
i = -1
j = 0
while i < reps:
while j < 4:
straight(sides)
rotate()
j+=1
i+=1
move = Twist()
#rate = rospy.Rate(10)
rospy.spin()
Hi @d.zablah,
I’d advice you to try to debug this on your own, its a small programming error. If you still can’t figure it out click on the arrow below.
Solution
You forgot to reset the variable j
in your while loop after its done executing its first repetition, the correct code should look like this:
i = -1
j = 0
while i < reps:
while j < 4:
straight(sides)
rotate()
j+=1
i+=1
j=0
Happy learning…!!
