How is the node name decided between node name initialized in python script vs the one mentioned in launch file
When launching a program from a launch file, which is the node that is initialised? is it the node mentioned in the python script using rospy.init_node("Node_created_from_python_script") or is it the one mentioned in the launch file as
<node pkg="package_name" type="name_of_python_script.py" name="Name_of_initialising_node" output="screen">
Example:
The python script python_script.py is launched by the package “my_package”, as below:
print("Node Created")
rospy.spin()
The launch file of package my_package is launch_file.launch is as below:
<launch>
<node pkg="my_package" type="python_script.py" name="Node_created_from_launch_node" output="screen">
</node>
</launch>
Upon running the launch file launch_file.launch , we get successful file output as:
SUMMARY
PARAMETERS
 * /rosdistro: noetic
 * /rosversion: 1.15.9
NODES
    Node_created_from_launch_node (my_package/python_script.py)
process[Node_created_from_launch_node-1]: started with pid [12186]
Node Created
Upon running the command rosnode list, the following output is received:
rosnode list
/Node_created_from_launch_node
/gazebo/rosout
/rostopic_2656_1632028662905
From above we see that the Node created has the node name mentioned in the launch file (/Node_created_from_launch_node) and not the node name mentioned in the python script (/Node_created_from_python_script).
***1. Where did the (/Node_created_from_python_script) disappear to? ***
2. Why is the launch node name given priority over the python script node name?
Interesting experiment and good question!
You have already found out from your experiment that the node name specified in the launch file wins. Maybe the one specified in the python file is just ignored, or is made to sit on the bench, or is even sent to /dev/null, but it really doesn’t matter. Once you specify the node name in the launch file, it takes precedence.
For one, it’s so that you can have control over the name of the node, especially if you are launching third-party packages (where you don’t have access to the code). It’s a design decision made by the ROS team, for our good.
Thank you @bayodesegun for clearing up the concepts. The support from fellow users is really commendable
