Hi, someone knows what library it’s the same but for c++?
I want to use for Real Basic Project C++
from tf.transformations import euler_from_quaternion
Hi @Voltedge ,
You would use #include <tf/tf.h>.
You must first convert quaternion to a matrix and then use matrix.getRPY(...) function.
Refer: Transform Quaternion - ROS Answers: Open Source Q&A Forum
PS: Please change the title to an appropriate title. Your current title does not hint what you want!
A better title would be “How to convert Quaternion to Euler in ROS C++?”.
