Hello there,
Can someone explain me why when I do CTRL-C I have the error below?
On the real robot the robot continues to move and even stopping with teleop it doesn’t stop until some time.
Thank you in advance for your help.
Pablo
user:~/ros2_ws$ ros2 launch wall_following_pkg find_wall.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2023-06-30-07-43-56-920300-2_xterm-5348
[INFO] [find_wall_service-1]: process started with pid [5350]
[find_wall_service-1] [INFO] [1688111037.068505519] [find_wall_service]: Robot simulated = 1
[find_wall_service-1] [INFO] [1688111042.532605931] [find_wall_service]: starting to wait for message
[find_wall_service-1] [INFO] [1688111042.533416142] [find_wall_service]: still waiting for message
[find_wall_service-1] [INFO] [1688111043.533600894] [find_wall_service]: message found
[find_wall_service-1] [INFO] [1688111043.533682551] [find_wall_service]: min value is at index 3
[find_wall_service-1] [INFO] [1688111043.533700081] [find_wall_service]: wall behind
[find_wall_service-1] [INFO] [1688111050.101255646] [rclcpp]: signal_handler(signal_value=2)
[ERROR] [find_wall_service-1]: process[find_wall_service-1] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
[INFO] [find_wall_service-1]: sending signal 'SIGTERM' to process[find_wall_service-1]
[ERROR] [find_wall_service-1]: process has died [pid 5350, exit code-15, cmd '/home/user/ros2_ws/install/wall_following_pkg/lib/wall_following_pkg/find_wall_service --ros-args -r __node:=find_wall_service'].
#include "geometry_msgs/msg/twist.hpp"
#include "rcl/event.h"
#include "rclcpp/rclcpp.hpp"
#include "rclcpp/subscription_base.hpp"
#include "rclcpp/subscription_options.hpp"
#include "rclcpp/utilities.hpp"
#include "rclcpp/wait_for_message.hpp"
#include "sensor_msgs/msg/detail/laser_scan__struct.hpp"
#include "sensor_msgs/msg/laser_scan.hpp"
#include "wall_following_pkg/srv/find_wall.hpp"
#include <chrono>
#include <functional>
#include <memory>
using FindWall = wall_following_pkg::srv::FindWall;
using std::placeholders::_1;
using std::placeholders::_2;
const bool SIMULATION = true;
class ServerNode : public rclcpp::Node {
public:
ServerNode() : Node("find_wall_server") {
RCLCPP_INFO(this->get_logger(), "Robot simulated = %d", SIMULATION);
callback_group_1_ = this->create_callback_group(
rclcpp::CallbackGroupType::MutuallyExclusive);
callback_group_2_ = this->create_callback_group(
srv_ = create_service<FindWall>(
"find_wall", std::bind(&ServerNode::find_wall_callback, this, _1, _2),
rmw_qos_profile_services_default, callback_group_1_);
publisher_ =
this->create_publisher<geometry_msgs::msg::Twist>("cmd_vel", 1);
this->laser_left = 0.0;
this->laser_right = 0.0;
this->laser_forward = 0.0;
this->laser_backward = 0.0;
private:
rclcpp::Service<FindWall>::SharedPtr srv_;
rclcpp::CallbackGroup::SharedPtr callback_group_1_;
rclcpp::CallbackGroup::SharedPtr callback_group_2_;
rclcpp::Publisher<geometry_msgs::msg::Twist>::SharedPtr publisher_;
rclcpp::Subscription<sensor_msgs::msg::LaserScan>::SharedPtr subscription_;
geometry_msgs::msg::Twist twist_msg;
float laser_left;
float laser_right;
float laser_forward;
float laser_backward;
bool scan_found;
void find_wall_callback(const std::shared_ptr<FindWall::Request> request,
const std::shared_ptr<FindWall::Response> response) {
// non intrusive function to avoid unused value warning
typeid(request).name();
auto scan_message = sensor_msgs::msg::LaserScan();
twist_msg.linear.x = 0.0;
twist_msg.angular.z = 0.0;
scan_found = false;
RCLCPP_INFO(this->get_logger(), "starting to wait for message");
start_scan_sub();
while (!scan_found) {
RCLCPP_INFO(this->get_logger(), "still waiting for message");
rclcpp::sleep_for(1s);
RCLCPP_INFO(this->get_logger(), "message found");
/*RCLCPP_INFO(this->get_logger(), "starting to wait for message");
scan_found =
rclcpp::wait_for_message(scan_message, this->shared_from_this(),
"/scan", std::chrono::seconds(1));
//RCLCPP_INFO(this->get_logger(), "still waiting for message");
RCLCPP_INFO(this->get_logger(), "scan_found = %d", scan_found);
this->laser_left = scan_message.ranges[90];
this->laser_right = scan_message.ranges[270];
this->laser_forward = scan_message.ranges[0];
this->laser_backward = scan_message.ranges[180];
std::vector<float> laser_values = {this->laser_left, this->laser_right,
this->laser_forward,
this->laser_backward};
int min_index = find_min_index(laser_values);
RCLCPP_INFO(this->get_logger(), "min value is at index %d", min_index);
switch (min_index) {
case 0:
RCLCPP_INFO(this->get_logger(), "wall on the left");
twist_msg.angular.z = 0.2;
break;
case 1:
RCLCPP_INFO(this->get_logger(), "wall on the right");
if (laser_right < 0.3) {
RCLCPP_INFO(this->get_logger(), "already in position, end of service");
response->wallfound = true;
return;
twist_msg.angular.z = -0.2;
break;
case 2:
RCLCPP_INFO(this->get_logger(), "wall in front");
twist_msg.linear.x = 0.05;
break;
case 3:
RCLCPP_INFO(this->get_logger(), "wall behind");
break;
// start_scan_sub();
while (laser_forward > laser_backward || laser_forward > laser_left ||
laser_forward > laser_right) {
publisher_->publish(twist_msg);
/*RCLCPP_INFO(this->get_logger(), "[FORWARD] = '%f'",
this->laser_forward); RCLCPP_INFO(this->get_logger(), "[LEFT] = '%f'",
this->laser_left); RCLCPP_INFO(this->get_logger(), "[RIGHT] = '%f'",
this->laser_right); RCLCPP_INFO(this->get_logger(), "[FORWARD] = '%f'",
this->laser_forward); RCLCPP_INFO(this->get_logger(), "[BACKWARD] = '%f'",
this->laser_backward);
// rclcpp::sleep_for(1s);
this->twist_msg.linear.x = 0;
this->twist_msg.angular.z = 0;
RCLCPP_INFO(this->get_logger(), "facing the wall, going to approach");
this->twist_msg.linear.x = 0.05;
while (laser_forward > 0.3) {
"close to the wall, rotating to start position");
this->twist_msg.angular.z = 0.2;
while (laser_right > laser_backward || laser_right > laser_left ||
laser_forward < laser_right) {
subscription_.reset();
RCLCPP_INFO(this->get_logger(), "in position, end of service");
int find_min_index(std::vector<float> laser_values) {
int length = laser_values.size();
// RCLCPP_INFO(this->get_logger(), "length= %d", length);
float min = laser_values[0];
int index = 0;
for (int i = 0; i < length; i++) {
// RCLCPP_INFO(this->get_logger(), " %f\n", laser_values[i]);
if (laser_values[i] < min) {
min = laser_values[i];
index = i;
return index;
void start_scan_sub() {
rclcpp::SubscriptionOptions sub_options;
sub_options.callback_group = callback_group_2_;
subscription_ = this->create_subscription<sensor_msgs::msg::LaserScan>(
"/scan", rclcpp::SensorDataQoS(),
std::bind(&ServerNode::scan_callback, this, _1), sub_options);
void scan_callback(const sensor_msgs::msg::LaserScan::SharedPtr msg) {
//RCLCPP_INFO(this->get_logger(), "SCAN CALLBACK");
if (SIMULATION) {
// RCLCPP_INFO(this->get_logger(), "number of angle values = '%d'",
// msg->ranges.size());
//-------------------------SIM SCAN VALUES 360 values
this->laser_left = msg->ranges[90];
this->laser_right = msg->ranges[270];
this->laser_forward = msg->ranges[0];
this->laser_backward = msg->ranges[180];
} else {
//---------------real turtle bot values 720 values angle_min:
//-3.1241390705108643 angle_max: 3.1415927410125732
this->laser_left = msg->ranges[540];
this->laser_right = msg->ranges[180];
this->laser_forward = msg->ranges[360];
this->laser_backward = msg->ranges[0];
scan_found = true;
RCLCPP_INFO(this->get_logger(), "[LEFT] = '%f'", this->laser_left);
RCLCPP_INFO(this->get_logger(), "[RIGHT] = '%f'", this->laser_right);
RCLCPP_INFO(this->get_logger(), "[FORWARD] = '%f'", this->laser_forward);
RCLCPP_INFO(this->get_logger(), "[BACKWARD] = '%f'", this->laser_backward);
int main(int argc, char *argv[]) {
rclcpp::init(argc, argv);
std::shared_ptr<ServerNode> find_wall_server = std::make_shared<ServerNode>();
rclcpp::executors::MultiThreadedExecutor executor;
executor.add_node(find_wall_server);
executor.spin();
rclcpp::shutdown();
return 0;
