How to finish the project in order to get the certificate?
Please open the Linux course and follow the units. At some point in time of the course, you will see that it tells you to open a ROS project (rosject) and follow its instructions. You need to finish that rosject and then request to do a Youtube presentation of your project. (check this channel for other students presentations: https://www.youtube.com/@becomingarosdeveloper6394).
Once you successfully do the presentation, you will get the certificate.
As you can see, getting a The Construct certificate requires a lot of work, not just watching a few videos. Our certificates are real and certify you with really acquired skills
so, the assessment is graded after the presentation?
