This error typically happens when you are using the comparison operator with an if statement in bash, and you did not write the statement correctly!
We’ll look at
- Why this error happens,
- two ways it can happen, and
- how you can fix (and better still, prevent) it.
You can
- copy the given scripts to your local Linux installation, or better still…
- use our online learning and development environment running right inside your browser!
Step 1: Create a test script
First, let’s create a test script that we will use for checking each of these reasons.
- Create a bash file in your workspace.
cd ~
touch unary_operator_test.sh
- Make it executable.
chmod +x unary_opeator_test.sh
- Copy and paste the content below into the file
unary_operator_test.sh, using nano or an IDE:
nano unary_operator_test.sh
# paste the content and save
#!/bin/bash
PROMPT="yes"
# capture the output of the command to OUT.
# "2>&1" ensures we capture error output too
OUT=`if [ $PROMPT = "yes" ]; then echo "Prompt is yes!"; fi 2>&1`
# print the output of the command
echo $OUT
if [[ "$OUT" = *"unary"* ]]; then
# A unary error occurred, exit with error
exit 1
elif [[ "$OUT" = *"yes"* ]]; then
# Output is 'Prompt is yes!', exit normally
exit 0
fi
# No unary error, but PROMPT is not "yes"
echo "PROMPT is not 'yes', but we have no error!"
Step 2: Test the script
Run:
./unary_operator_test.sh
# or
bash unary_operator.sh
You should get an output like the following:
user:~$ bash unary_operator.sh
Prompt is yes!
So it worked, but it will fail sometimes. We’ll see how it can fail in the next section.
Step 3: Make the script fail. Yes, you read that correctly!
- Change the code so that
PROMPT="":
#!/bin/bash
PROMPT=""
echo $OUT
exit 1
exit 0
fi
Run the script again:
You should now have this output:
unary_operator.sh: line 6: [: =: unary operator expected
Gotcha, we have the error! Why? Let’s find out another way it could happen. After that, we summarize.
- Change the script again, to the following:
#!/bin/bash
# assign the first argument passed to the script to PROMPT
PROMPT=$1
echo $OUT
exit 1
exit 0
fi
Run it again.
The same error as before:
But wait…before you give up, run the script differently now:
bash unary_operator.sh yes
Now it works:
user:~$ bash unary_operator.sh yes
Prompt is yes!
But, why? Let’s summary the lessons in the next and final section.
Step 4: Understand why the error happens
As you might have noticed, this error happens whenever $PROMPT is not set. That is, when it’s equal to an empty string "" or not defined.
In this case, line 5 becomes:
if [ = "yes" ]; then
and this causes the error to happen because it’s incomplete.
Let see why the script worked and failed in Step 3.
- In Step 3 (1), the PROMPT was set to “yes”, so it worked.
- In Step 3 (2), the PROMPT was set to “”, so there was an error.
- In Step 3 (3),
- The PROMPT was set to “” initially, because we did not pass any argument to the script, so the error happened.
- Then we passed an argument “yes” to the script, and it worked.
Step 5: How can we prevent the “unary error” from appearing?
Quote the variable $PROMPT on line 5. That simple.
Let’s repeat Step 3 (2) and Step 3 (3) with $PROMPT quoted.
- Change the script to:
#!/bin/bash
PROMPT=""
OUT=`if [ "$PROMPT" = "yes" ]; then echo "Prompt is yes!"; fi 2>&1`
echo $OUT
exit 1
exit 0
fi
Then run:
You should have:
PROMPT=$1
echo $OUT
exit 1
exit 0
fi
Then run:
Again, you should have:
If you run:
You should have:
Prompt is yes!
6. Wrap up and consolidate
- Did you understand why not quoting the variable in the if statement on line 5 causes the “unary operator”?
- What would happen if you misspelled
$PROMPTon line 5, writing it as$PRIMPTfor instance? Try it out, not quoting variable at first, and then quoting it.
Reference posts:
- ["bash: : =: unary operator expected" on Linux for Robotics course - Course Support / Linux Basics For Robotics - The Construct ROS Community (robotigniteacademy.com)
- Exe 4.1: unary operator expected error - Course Support / Linux Basics For Robotics - The Construct ROS Community (robotigniteacademy.com)
