Hi all, I have written a class called move_drone_class under the filename move_drone.py in a separate package called square_drone.
Now I want to access it from a new file called script.py created inside another package testpkg
script.py is as below:
from move_drone import move_drone_class
if __name__ == '__main__':
rospy.init_node("AccessClassFromNewPackage")
move_drone_obj=move_drone_class()
move_drone_obj.takeoff()
move_drone_obj.move_around_in_random()
rospy.sleep(3)
move_drone_obj.land()
1.When i try to access it, I get the following error, Can you help solve this? The chapter “using python classes” in ROS 5 days basics, talks about this, but there the file imported was from the same package.
2.Is it a convention to copy the file we want to import, into the current package we are working on? because this method worked for me
File "/home/user/catkin_ws/src/testpkg/src/script.py", line 3, in <module>
ModuleNotFoundError: No module named 'move_drone'
