can anyone suggest proper method of interfacing arduino with ros2.
The task is to run 6 stepper motors and get encoder values from the sensors and get reading from other sensors like temperature sensor.
Hi, welcome to the community!
You can use micro-ROS for that: https://micro.ros.org/
hi, is there any possibility to interface with publisher and subscriber like ros1
I have never done this, but maybe with mqtt:
