Based on the knowledge I learned from the course. I wrote a plugin to serve a virtual wall based on ROS1. But I don’t really understand the algorithm inside it. I want to know if there is a way to check whether the plugin is loaded into the system or not and what order to place it in the available layers. Can someone help me? I can provide the code below:
amcl:
ros__parameters:
use_sim_time: False
alpha1: 0.2
alpha2: 0.2
alpha3: 0.2
alpha4: 0.2
alpha5: 0.2
base_frame_id: "base_footprint"
beam_skip_distance: 0.5
beam_skip_error_threshold: 0.9
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: "map"
lambda_short: 0.1
laser_likelihood_max_dist: 2.0
laser_max_range: 100.0
laser_min_range: -1.0
laser_model_type: "likelihood_field"
max_beams: 60
max_particles: 2000
min_particles: 500
odom_frame_id: "odom"
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 1
robot_model_type: "nav2_amcl::DifferentialMotionModel"
save_pose_rate: 0.5
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 1.0
update_min_a: 0.2
update_min_d: 0.25
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
scan_topic: scan
# Set init pose Localiztion
set_initial_pose: true
initial_pose:
x: 0.336452
y: -0.0605629
yaw: 0.00679869
amcl_map_client:
ros__parameters:
use_sim_time: False
amcl_rclcpp_node:
ros__parameters:
use_sim_time: False
# Trung gian giua Global plan va local plan
bt_navigator:
ros__parameters:
use_sim_time: False
global_frame: map
robot_base_frame: base_link
odom_topic: /odom
default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
bt_loop_duration: 10
default_server_timeout: 20
enable_groot_monitoring: True
groot_zmq_publisher_port: 1666
groot_zmq_server_port: 1667
plugin_lib_names:
- nav2_compute_path_through_poses_action_bt_node
- nav2_back_up_action_bt_node
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_recovery_node_bt_node
- nav2_single_trigger_bt_node
- nav2_is_battery_low_condition_bt_node
- nav2_navigate_through_poses_action_bt_node
- nav2_navigate_to_pose_action_bt_node
- nav2_remove_passed_goals_action_bt_node
- nav2_planner_selector_bt_node
- nav2_controller_selector_bt_node
- nav2_goal_checker_selector_bt_node
bt_navigator_rclcpp_node:
ros__parameters:
use_sim_time: False
controller_server:
ros__parameters:
use_sim_time: False
controller_frequency: 10.0
min_y_velocity_threshold: 0.5
failure_tolerance: 0.3
progress_checker_plugin: "progress_checker"
goal_checker_plugins: ["general_goal_checker"]
controller_plugins: ["FollowPath"]
# Progress checker parameters
progress_checker:
required_movement_radius: 0.5
movement_time_allowance: 10.0
general_goal_checker:
stateful: True
xy_goal_tolerance: 0.25
yaw_goal_tolerance: 0.25
# DWB parameters
FollowPath:
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.22
max_vel_y: 0.0
max_vel_theta: 1.0
min_speed_xy: 0.0
max_speed_xy: 0.22
min_speed_theta: 0.0
# Add high threshold velocity for turtlebot 3 issue.
# https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 0
vtheta_samples: 40
sim_time: 1.5
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.2
xy_goal_tolerance: 0.05
trans_stopped_velocity: 0.25
stateful: True
# critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
critics: ["RotateToGoal", "Oscillation", "ObstacleFootprint", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
ObstacleFootprint.scale: 0.02
PathAlign.scale: 32.0
GoalAlign.scale: 24.0
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
controller_server_rclcpp_node:
ros__parameters:
use_sim_time: False
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 5.0
publish_frequency: 2.0
global_frame: odom
use_sim_time: False
rolling_window: true
# Size of Costmap area around the robot
width: 3
height: 3
resolution: 0.05
# robot_radius: 0.1
footprint: '[ [0.089, 0.069], [0.089, -0.069], [-0.089, -0.069], [-0.089, 0.069] ]'
# plugins: ["obstacle_layer", "voxel_layer", "inflation_layer", "virtual_wall"]
plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
inflation_layer:
plugin: "nav2_costmap_2d::InflationLayer"
inflation_radius: 1.0
cost_scaling_factor: 3.0
obstacle_layer:
plugin: "nav2_costmap_2d::ObstacleLayer"
enabled: True
observation_sources: scan
scan:
topic: /scan
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
# virtual_wall:
# # plugin: virtual_wall/VirtualWall
# plugin: virtual_wall/VirtualWall"
# enabled: True
voxel_layer:
plugin: "nav2_costmap_2d::VoxelLayer"
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
scan:
topic: /scan
clearing: True
marking: True
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
static_layer:
map_subscribe_transient_local: True
always_send_full_costmap: True
local_costmap_client:
ros__parameters:
use_sim_time: False
local_costmap_rclcpp_node:
ros__parameters:
use_sim_time: False
global_costmap:
global_costmap:
ros__parameters:
update_frequency: 1.0
publish_frequency: 1.0
global_frame: map
use_sim_time: True
robot_radius: 0.1
resolution: 0.05
track_unknown_space: true
plugins: ["static_layer", "obstacle_layer", "voxel_layer", "inflation_layer","virtual_wall"]
# plugins: ["static_layer", "obstacle_layer", "voxel_layer", "inflation_layer"]
virtual_wall:
enabled: True
obstacle_layer:
enabled: True
scan:
topic: /scan
clearing: True
marking: True
# Pointcloud Data
voxel_layer:
enabled: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
scan:
topic: /scan
clearing: True
marking: True
static_layer:
plugin: "nav2_costmap_2d::StaticLayer"
inflation_layer:
inflation_radius: 0.55
global_costmap_client:
ros__parameters:
use_sim_time: False
global_costmap_rclcpp_node:
ros__parameters:
use_sim_time: False
map_server:
ros__parameters:
use_sim_time: False
yaml_filename: "map.yaml"
map_saver:
ros__parameters:
use_sim_time: False
save_map_timeout: 5.0
free_thresh_default: 0.25
occupied_thresh_default: 0.65
planner_server:
ros__parameters:
expected_planner_frequency: 20.0
use_sim_time: False
planner_plugins: ["GridBased"]
GridBased:
plugin: "nav2_navfn_planner/NavfnPlanner"
tolerance: 0.5
use_astar: false
allow_unknown: False
planner_server_rclcpp_node:
ros__parameters:
use_sim_time: False
recoveries_server:
ros__parameters:
costmap_topic: local_costmap/costmap_raw
footprint_topic: local_costmap/published_footprint
cycle_frequency: 10.0
recovery_plugins: ["spin", "backup", "wait"]
spin:
plugin: "nav2_recoveries/Spin"
backup:
plugin: "nav2_recoveries/BackUp"
wait:
plugin: "nav2_recoveries/Wait"
global_frame: odom
transform_timeout: 0.1
use_sim_time: true
simulate_ahead_time: 2.0
max_rotational_vel: 1.0
min_rotational_vel: 0.4
rotational_acc_lim: 3.2
robot_state_publisher:
ros__parameters:
use_sim_time: False
waypoint_follower:
ros__parameters:
loop_rate: 2000
stop_on_failure: false
waypoint_task_executor_plugin: "wait_at_waypoint"
wait_at_waypoint:
plugin: "nav2_waypoint_follower::WaitAtWaypoint"
enabled: True
waypoint_pause_duration: 200
I have configured like that, when loading Rviz, it displays the results:
