Hey team,
how I can publish a message one time in ros2 using python.
I really appreciate your kind support and assistance.
Hello @mbzuaimbzirc,
one posible way is to apply a transient local QOS setting profile to your publisher.
For instance using this minimal publisher example taken from ROS Answers.
Source: ros2 latching - ROS Answers: Open Source Q&A Forum
#!/usr/bin/env python
import rclpy
from rclpy.node import Node
from rclpy.qos import QoSProfile, QoSDurabilityPolicy
from std_msgs.msg import String
class Latching(Node):
super().__init__('latching')
latching_qos = QoSProfile(depth=1, durability=DurabilityPolicy.TRANSIENT_LOCAL)
pub = self.create_publisher(String, 'foo', qos_profile=latching_qos)
msg = String(data='test')
pub.publish(msg)
def main(args=None):
rclpy.init(args=args)
node = Latching()
try:
rclpy.spin(node)
except KeyboardInterrupt:
node.get_logger().info("Ctrl-C detected, shutting down")
finally:
node.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
Cheers,
Roberto
