bonjour
i have a run problem with a customized msg in a package "titi "colcon builded OK
and used a the py-pysub package /talker and listener nodes colcon buided OK
self.publisher_ = self.create_publisher(NumBer , ‘topic’, 10) : NumBer is the customized msg
in package titi , showable with ros2 interface show : as float32 num
I get : rclpy._rclpy_pybind11.RCLError: Failed to create publisher: Type support not from this implementation. Got:
Could not load library libtiti__rosidl_typesupport_fastrtps_c.so: dlopen error: libtiti__rosidl_typesupport_fastrtps_c.so: cannot open shared object file: No such file or directory,
I use Ubuntu 22.04 / ROS2 Iron under a WSL machine win11 7 cores
how to solve this error ?
thanks
