While taking Linux for Robotics, I deleted the catkin_ws directory. Everything is gone and I don’t know how to return or fix it. I cannot do anything with the simulator now. Please help
Try reloading the IDE and click kill and start a new shell.
Dat is niet zo best ik zou gewoon uitschrijven
Lekker bezig pik, begint goed
@WoutFranken Generally in a Linux system you can recover it from trash.
In this case try logging into course again.
If this does not happen, Try mailing constructsim they will always have a backup similar to trash in local system and they can restore it.
Good luck
Hi @WoutFranken,
After checking the versions of your files, I see you were able to recover the catkin_ws when opening the course again, right?
